Stuck in 2nd gear HELP!
hey guys my friend has an ex coupe 93. stock motor and everything, for some reason just yesterday it has been hard to shift in an out of gears and that night it got stuck in 2nd gear, it will not come out, i have no idea what to check so if you guys got ne ideas please help. It had problems shifting into third before this happened, earlyer in the day and at night it just seized up and wont shift out of second. the car starts rite up when pushing in the clutch it just wont come out of gear.
would it still be the clutch because i can drive it in 2nd gear it just wont come out of it. the car still moves so it cant be the clutch could it?
Modified by jdm_eg at 3:17 PM 12/20/2004
Re: Stuck in 2nd gear HELP! (jdm_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_eg »</TD></TR><TR><TD CLASS="quote">hey guys my friend has an ex coupe 93. stock motor and everything, for some reason just yesterday it has been hard to shift in an out of gears and that night it got stuck in 2nd gear, it will not come out, i have no idea what to check so if you guys got ne ideas please help. It had problems shifting into third before this happened, earlyer in the day and at night it just seized up and wont shift out of second. the car starts rite up when pushing in the clutch it just wont come out of gear.</TD></TR></TABLE>
Sounds like the clutch is either busted (spring(s) in the disc broke off) or the throwout bearing went out on you. I've even seen it where the flywheel came off of the block. But since the car will be in neutral when you start it up, sounds like the disc or could be the tranny. You're still able to start the car because when you push the clutch pedal in, there is a momentary switch behind it that closes and completes the circuit telling the computer that the car is in neutral. You're going to have to remove the transmission and inspect the clutch, flywheel, and throwout bearing. While the tranny is out, get a screwdriver and go through all of the gears to make sure it still goes into each gear just fine. With the tranny out and it's stuck in gear and won't go, then you know it's something inside the tranny.
Re: (jdm_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_eg »</TD></TR><TR><TD CLASS="quote">newman hit the nail rite on the head</TD></TR></TABLE>
Re: (Hatch-N-si)
I blew up my throwout bearing and it wouldn't go into or come out of gear when the car was runing. If I turned it of it was better, so I just put it in 3rd and drove home. Larry
Re: Stuck in 2nd gear HELP! (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">
Sounds like the clutch is either busted (spring(s) in the disc broke off) </TD></TR></TABLE>
I have a 95EX, and my car did the same thing. A spring came out of the disc, and another was falling out.
jl110ex
11
09-21-2004 07:35 AM
