what should i have my fuel pressure set at?
hey guys just wondering what fuel pressure b20 guys are running here is my set up
93 civic cx
jdm b20b
rc 310cc injectors
sard fuel pressure regulator
walbro 255 fuel pump
and if it matters all s.s. fuel lines and earls inline fuel filter
also im running the 1.8L ls 5 spd ecu (obd1)
it was currently set at 40psi and was told by my boss it sounded like it had a lean missfire?
any info would be appreciated also info on your similar set up would help as well
93 civic cx
jdm b20b
rc 310cc injectors
Re: what should i have my fuel pressure set at? (eg_type_r93)
easy way to check is to check you plugs and see if you are running lean.
what kind of engine management are you using or chip program.
its hard to says what psi you should run at. my motor i had it set at stock which was 47psi. i also has 310s best way to kno is to take the car and have it tuned.
Re: what should i have my fuel pressure set at? (LSVtecEK1)
im just running the stock 1.8l ls ecu, is this a bad thing?
stock is 47psi, ok thx ill check the plugs
