Poor Mans R....Which Headgasket??
Like title says..Im in the process of putting a gsr block to my b16 head.
I was wondering which headgasket would be my best bet. I work at an acura dealer so i can get OEM gaskets cheap.
thanks for any input...
ps..Ive done some seaches but not to specific on headgaskets used in poor mans r
Re: Poor Mans R....Which Headgasket?? (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">all B series VTEC headgaskets are the same</TD></TR></TABLE>
So your saying theres no difference in the GSR,ITR, and LS....(EDIT on the LS, Just realized "VTEC"
If so my prob. is solved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote"> 12251-P30-014</TD></TR></TABLE>
Honda part number??
Honda part number??
Re: Poor Mans R....Which Headgasket?? (EGinNY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGinNY »</TD></TR><TR><TD CLASS="quote">Honda part number??</TD></TR></TABLE>
its the same part number from Honda or Acura.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">u sure u work at the dealer? </TD></TR></TABLE>
Never said i worked in the parts department nor do i know the part numbers to all there parts and which are the same.....I just work there and i get parts at cost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fred n J’s_1.8’s »</TD></TR><TR><TD CLASS="quote">its the same part number from Honda or Acura.</TD></TR></TABLE>
I was gonna put "acura part number" but i figured someone was gonna tell me its "honda"
So my question was:
is this there (Honda/Acura) part number
So my question was:
I would upgrade the headgasket, you can get a steel one from Mr. gasket for a few bucks more, and it will hold up better over time. Dont go cheap on the most important sealing surface on your engine. Why go stock, when you can up grade.
So my question was:
12251-P30-014
BOTH
So my question was:
12251-P30-014
BOTH
Re: Poor Mans R....Which Headgasket?? (ObedD15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ObedD15 »</TD></TR><TR><TD CLASS="quote">I would upgrade the headgasket, you can get a steel one from Mr. gasket for a few bucks more, and it will hold up better over time. Dont go cheap on the most important sealing surface on your engine. Why go stock, when you can up grade.</TD></TR></TABLE>
honda oem gaskets are steel ones already. and they ahve proven over and over to hold 20+ psi of boost as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ObedD15 »</TD></TR><TR><TD CLASS="quote"> Why go stock, when you can up grade.</TD></TR></TABLE>
Why change when stock has been proven effective?
Re: Poor Mans R....Which Headgasket?? (ITR 98 1162)
So your car is stock then, I mean if it came on the car then why upgrade it when it goes bad. Who really goes to honda for wiper blades? Yeah the worked but why pay the money when you can get a better quality product for the same and even some times cheaper price? Thats all I was saying. Good luck and keep those post number up.
Guest
Posts: n/a
I had a poor man's R.
I drilled out the pins on the Honda gasket and took the middle layer out. No leakage although I assure you it's a risk. Then I coated it with copper spray and quickly put the head on so the gasket can seat well.
Compression was about 11.5/1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ObedD15 »</TD></TR><TR><TD CLASS="quote">So your car is stock then, I mean if it came on the car then why upgrade it when it goes bad. Who really goes to honda for wiper blades? Yeah the worked but why pay the money when you can get a better quality product for the same and even some times cheaper price? Thats all I was saying. Good luck and keep those post number up. </TD></TR></TABLE>
12251-P30-014 GASKET, CYLINDER HEAD $60.63
MRG-3187G
Head Gasket, Multi Layered Steel, 82 mm. Bore, .030 in. Compressed Thickness, Acura/Honda, Each
$69.88
MRG-3187G
$69.88
