msd ignition problems
before i put it in i had no check engine light and as soon as i put it in i got code 9 number one cylinder position sensor i cleaned up the wiring and everything and its still there... if anyone else had this problem? if so how did you solve it...
Re: msd ignition problems (wht_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wht_eg »</TD></TR><TR><TD CLASS="quote">before i put it in i had no check engine light and as soon as i put it in i got code 9 number one cylinder position sensor i cleaned up the wiring and everything and its still there... if anyone else had this problem? if so how did you solve it...</TD></TR></TABLE>
If you cleared the problem, and then cleared the ECU, then the code should be gone, or a different code is being thrown.
boostng r
10-26-2004 11:49 AM
