cel code 43
Old 12-12-2004, 09:24 AM
mattharper's Avatar
Default cel code 43
fuel supply problem
its a stock 92 dx. i have not had any problems yet but my cel is on code 43.
what could casue this problem.
Old 12-12-2004, 09:28 AM
Bimmer99's Avatar
Default Re: cel code 43 (mattharper)
i believe that's a good indicator you need an o2 sensor
Old 12-12-2004, 09:36 AM
mattharper's Avatar
so this isnt an urgent issue then? is it even worth fixing if the motor is only gonna be in for another month or so?
Old 12-12-2004, 01:52 PM
mattharper's Avatar
well i drove to the mall, it was bogging out and almost stalling, then when it stopped bogging tons of white smoke blew out
then when i finally park the car, it was bogging, i tried to give it a rev, loads of white smoke again, then stalled, now it wont start
any ideas??
btw the car used to bogg whenever it rained... that started like2 months ago
Old 12-12-2004, 03:50 PM
ironlung78's Avatar
Default Re: (mattharper)
white smoke=not good!!!
drain the engine oil and check to make sure there is no anti freeze in there.
if there is congratulations you have a bad headgasket.
Old 12-12-2004, 04:58 PM
mattharper's Avatar
if its a bad head gasket then why code 43??
Old 12-12-2004, 05:11 PM
t0p_sh0tta's Avatar
I got the same code for a bad distributor. The eg's are known for distributor problems.
Old 12-13-2004, 04:06 AM
ironlung78's Avatar
regardless white smoke aint good and you should still check the oil
if you had a bad head gasket then the antifreeze that you would be trying to burn off in your oil could clog your converter or ruin an 02 sensor and in turn throw a cel!
Old 12-20-2004, 09:02 AM
miltownvtec's Avatar
hey dude!
if you ever find out bout the code, let me know to?
onytay06
02-22-2018 03:57 PM
dc2lee
02-14-2017 12:56 PM
RCautoworks
28
10-03-2011 04:51 PM
mattharper
12-12-2004 01:05 PM
Quick Reply: cel code 43
