removing oil off the ground
Re: removing oil off the ground (komat)
well for the oil on the ground dawn dish soap and a hard bristle broom works. and the head is it still on the engine or off?? look at jdmlyfestyle for engine cleaning. his profile is at top of the page in a sticky thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">whats the best product that will remove oil off the ground and also something to clean the engine head</TD></TR></TABLE>
when we spill oil, we pour kitty litter on it, let it sit for like 20 mins till it soaks in, then sweep it up
Re: removing oil off the ground (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff »</TD></TR><TR><TD CLASS="quote">
when we spill oil, we pour kitty litter on it, let it sit for like 20 mins till it soaks in, then sweep it up</TD></TR></TABLE>
That's the way to go for oil spills on the ground. As for oil cleaning of your head, use engine degreaser or carb cleaner, those seem to work good.
Re: removing oil off the ground (DavidT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidT »</TD></TR><TR><TD CLASS="quote">
That's the way to go for oil spills on the ground. As for oil cleaning of your head, use engine degreaser or carb cleaner, those seem to work good. </TD></TR></TABLE>
Break Parts Cleaner works miracles dries fast too
Kitty litter owns. If you want to pull the stain up a bit, lay down enough to get any residual puddle on the surface, let that get completely saturated. Sweep that up, then lay down some fresh stuff, grind it in a little, and let that sit a bit, sweep that up, and should look alot better.
Re: removing oil off the ground (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">
Kitty litter owns. If you want to pull the stain up a bit, lay down enough to get any residual puddle on the surface, let that get completely saturated. Sweep that up, then lay down some fresh stuff, grind it in a little, and let that sit a bit, sweep that up, and should look alot better.</TD></TR></TABLE>
Hmmmm, never knew that i will try that, there are a assload of stains on the floor
I use dishwashing soap on my hands after I work on my car and get lots of oil on them. I'd imagine it would work on pavement just as well.
Re: removing oil off the ground (chowmien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">Kitty litter owns..</TD></TR></TABLE>
so does gojo and dishwashing soap works for smoke grease on windows too!!
Also what works good for soaking up oil stains is odor absorbant powder. I work with fuel oil, and use this stuff all the time to cover up the smell/pick up/soak up stains. Works great on concrete. You can probably find this type of product under several different names if you went to a plumbing/heating supply store. Stuff I use is from F.W. Webbs (not sure if they are Northeast only) and is simply called "Odor Absorbant Powder", smells like cherries too!
most hood white kid
if it is a recent spill like if u spill it and it has only been 5 minutes, cat litter soaks it up, but it will still stain, i recommend a high power pressure washer for that
most hood white kid
Re: removing oil off the ground (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">
so does gojo and dishwashing soap works for smoke grease on windows too!!</TD></TR></TABLE>
gojo owns, that and lava are what I use on my hands after i get through working on my car.
Use gasoline....Thats stuff always remove oil rite off the ground. I use gasoline every time i spill oil from changing my oil all the time.
Re: (murtnabila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murtnabila »</TD></TR><TR><TD CLASS="quote">Rice ash from Napa Auto parts...check your local parts shop. Used kitty liter b4 and now never again...</TD></TR></TABLE>
Rice hull ash is the rulinest. Other than that sometimes at work we squirt oil stains with a caustic degreaser and power wash it off into a sewer sump (do not wash into the rain gutters).
For engine exteriors we also degrease and rinse, but you have to cover your electronics.
For engine head interiors, ever been thru the Seafoam experience?
