How are my spark plugs?
Re: How are my spark plugs? (intezn)
They suck.........they're denso. J/k http://www.mopar.com/m_maint_i....html
Check there, it has some good information. NGK>Denso
Re: How are my spark plugs? (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life »</TD></TR><TR><TD CLASS="quote">They suck.........they're denso. J/k http://www.mopar.com/m_maint_i....html
Check there, it has some good information. NGK>Denso </TD></TR></TABLE>
Good info site
Good info site
Re: (Average Al)
yea, there was some oil on them.
and don't know if this is normal or not, my 95 b18b, the running temp is half way the temp gauge, the stock civic si one.
Re: (intezn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intezn »</TD></TR><TR><TD CLASS="quote">and don't know if this is normal or not, my 95 b18b, the running temp is half way the temp gauge, the stock civic si one. </TD></TR></TABLE>
My stock d16y8 w/ 135,000 on it is the same way on my 96 ex cluster. Your temp is fine.
Electrician
You'll need to replace your o-rings that sit where the spark plugs are, you're letting oil seep into them.
Get yourself some NGK V-Power and gap them to 1.1mm via Honda spec.
Make sure your timing is within spec aswell.
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">You'll need to replace your o-rings that sit where the spark plugs are, you're letting oil seep into them.
Make sure your timing is within spec aswell.</TD></TR></TABLE>
will do so next week
also, i am little worry that my motor is running little too hot.
i'll get a pix of the temp tomorrow.
and where can i get some NGK plugs, Autozone? Napa?
Electrician
NGKs can be bought at any parts store.
Change your thermostat and flush your radiator and top it off. See if that helps. Definitely get a OEM thermostat.
Re: (civichatch6989)
if anything i would go with the hot call, but they are kinda cheesey plugs. You could go one level colder on the plugs for safetys sake, i think it would be a 6?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intezn »</TD></TR><TR><TD CLASS="quote"> .....
They look kinda white, so i am a bit worry </TD></TR></TABLE>
How many miles were on those? The color and electrode deformities could indicate plain ole lack of tune. The white could be from burn temp out of range, or from a lean burn, from possible cloggage in the FI's, high octane, fuel delivery prob (gas cap ok?), primarily commuting long-distance at high speed over the years???
Re: How are my spark plugs? (f1z1c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1z1c »</TD></TR><TR><TD CLASS="quote">How many miles were on those? The color and electrode deformities could indicate plain ole lack of tune. The white could be from burn temp out of range, or from a lean burn, from possible cloggage in the FI's, high octane, fuel delivery prob (gas cap ok?), primarily commuting long-distance at high speed over the years???</TD></TR></TABLE>
I haven't replace the plug for about 2 years.
I would say i have put about 20k on these.
I picked up this motor at about 80k and now has about 100k on it.
What can I do if I am running lean?
Yes, my gas cap is ok, and I just did a sea foam last week and smoked like heck
i'll hopefully replace these by wednesday, Final Paper > Me
what else can i check?
* B A N N E D *
1 Post
Re: (minimesleeper94)
the seal is bad, oil gettin in. they look a tad hot.
seriously, your honda (all of them) should use NGK. they are the best for your motor hands down. ngk iridium. best plug, and will give ya 100,000 miles at normal driving.
milkwasabadidea
11
08-29-2011 08:08 PM
