b16a2 into 93 del sol
I Think I'm TOO White For This Thread
i have a 93 del sol. i just swapped a jdm b16a2 into it. problems i have with it is how do i install a knock sensor, is 94 del sol VTEC axle ok and i have a lsd on the tranny. it came stock. but i'm not sure if both the axle should spin together at the same time when rotating one of them or if your going and one wheel loses trackion then the other wheel will pick up tracktion. on the knock sensor problem, i dont know where the plug at and where inside the car do i hook it up to. opinion will greatly be appreciated and any other opinion about swaping a b16 in to a del sol will also be appreciated. thanks
TSPeed Factory
Re: b16a2 into 93 del sol (gsrpwr2004)
you have to look for the wiring diagram for a knock sensor and then wire it up. the picture is floating around here somewhere.
Re: b16a2 into 93 del sol (AzntaggeR)
hmm ok where to start
first there is not such thing as a JDM b16a2. B16a2 is out of a 96-97 del sol vtec and 99-00 Civic SI.
to make sure it has LSD look through the hole where you put the axels into the tranny , if there is a bar going through it then its not LSD, if it doesnt it is. LSD will make both tires spin at the same time
any 94-00 integra, 94-97 del sol vtec, or 99-00 SI axle will work
knock sensor is below the intake manifold above the oil filter, and it goes to pin D6 on the ecu
hope that helps
hope that helps
1 Post
he's probably referring to 2nd gen b16 which is obd1 already. Like previous reply said check through hole if it goes straight through. only one wheel should move when if you have lsd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpwr2004 »</TD></TR><TR><TD CLASS="quote">well its a obd1 and its a b16a2</TD></TR></TABLE>
there was never a b16a2 made that was obd1, you can be using a obd1 ecu and dizzy but b16a2 was only put in 96+ civic/ del sol
Re: b16a2 into 93 del sol (Timmay)
i guess someone could have swapped everting (injectors, ecu, dizzy, etc.) but all i know is bmine came obd1 when i got it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">
there was never a b16a2 made that was obd1, you can be using a obd1 ecu and dizzy but b16a2 was only put in 96+ civic/ del sol</TD></TR></TABLE>
i have an A2 in my del sol...the 99-00 Si's had A3s...oh yeah, and A2s are OBDI
Re: b16a2 into 93 del sol (Falqon)
well that's odd...my buddy's 00Si has an OBDII A3, and my JDM A2 is OBDI...in fact...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">For this installment, we decided to further evaluate the B16A3, which is now standard equipment on the 2000-and-up Civic Si. Follow along as we get to the thick of things and tach out the high-revving twin-cam.
from import tuner... http://www.importtuner.com/tech/0103it_ppcivicsi/
Re: (someforlight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by someforlight »</TD></TR><TR><TD CLASS="quote">b16a2 is definitely the usdm 99-00 civic si motor
b16a3 is definitely the usdm del sol motor
any other responses and you are tripping. </TD></TR></TABLE>
B16A3 = USDM del Sol and atleast 2000 Si
B16A2 = JDM del Sol (SiRII) = OBDI = What he's talking about
Re: b16a2 into 93 del sol (xZeler8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xZeler8 »</TD></TR><TR><TD CLASS="quote">well that's odd...my buddy's 00Si has an OBDII A3, and my JDM A2 is OBDI...in fact...
from import tuner... http://www.importtuner.com/tech/0103it_ppcivicsi/</TD></TR></TABLE>
Scroll down on that page, it's a typo, or a dumb editor who cares more about some ricey exhaust than the engine
"The Car: 2000 Civic Si
The Owner: Chris Castillo
Engine Tested: B16A2
Applications: '00 CIVIC Si
Common Swaps: del Sol, Civic "
And a real JDM engine doesn't have a number after the A
ok this is how it goes
96-97 Del sol VTEC has obd2a b16a2
94-95 Del sol VTEC has obd1 b16a3
99-00 SI had obd2b b16a2
There is no such motor as a JDM b16a2
now there are versions of jdm b16s but they just go by obd1, obd0, obd2 etc...
Just like the other guys said, JDM motors dont have numbers after the last letter
And Import Tuner is ******* dumb if they think that the 99-00 SI came with a b16a3, i bet it was a typing error
right, my SiRII doesn't have a number after the letter A...per hmo when i bought the motor and superhonda.com the SiRII is a JDM B16A2...*shrug*...all i know is the guy is asking about a SiRII (i assume, hence the "jdm B16A2" he said) which is infact OBDI...
import tuner could have very well fucked up, again *shrug*
in a sense a "SIR2" JDM b16a is the same as a b16a3 being obd1, but the jdm is rated at just a little more power
all b16a2's are obd2
very good, if that's the case i stand corrected...but i'm 99% sure my buddy's Si has a stock B16a3 in it...i'll find out for sure, i could be wrong again, who knows
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xZeler8 »</TD></TR><TR><TD CLASS="quote">very good, if that's the case i stand corrected...but i'm 99% sure my buddy's Si has a stock B16a3 in it...i'll find out for sure, i could be wrong again, who knows</TD></TR></TABLE>
it may have one, but not from the factory
they never made a b16a3 in obd2B only obd2a(96-98)
all 99-00 SI's came with b16a2
ZCcivic91
12-13-2018 08:48 AM
jd2dub07
09-23-2007 08:59 AM
asmallsol
11-03-2003 12:30 PM
