vss problem
vss problem
ok guys i my speedometer was not working and i was not able to hit vtec. i checked my codes and i was throwing code 17(vss, speed sensor). So i got a new one and when i took my car for a drive i was able to hit vtec but my speedometer was still not working. all of a sudden my speedometer began go bounce up and down. then my check engine light came on and i was not able to hit vtec. Do you think it could be the plug on my harness?what do i do?
Re: vss problem (jaydm ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio »</TD></TR><TR><TD CLASS="quote">ok guys i my speedometer was not working and i was not able to hit vtec. i checked my codes and i was throwing code 17(vss, speed sensor). So i got a new one and when i took my car for a drive i was able to hit vtec but my speedometer was still not working. all of a sudden my speedometer began go bounce up and down. then my check engine light came on and i was not able to hit vtec. Do you think it could be the plug on my harness?what do i do?</TD></TR></TABLE>
what did i tell you in one of the other 10 threads you made about this problem
check the damn connector before you waste time and money putting a different VSS in. the connector is probably dirty, just look at it.
Re: vss problem (Kamin)
no money wasted *** it was free
if you dont like my post then keep your mouth shut and dont tell me what you think
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio »</TD></TR><TR><TD CLASS="quote">no money wasted *** it was free </TD></TR></TABLE>
you wont listen to simple troubleshooting advice so im done with you. have fun with your B18c non vtec, douche
BTW you made 10 ******* threads about this problem. you are a god damn retard.
Modified by Kamin at 3:22 PM 12/12/2004
i dont have a b16, gsr jdm b16 tranny.. muahaha
oh yea it works.. listen out you might hear me smash vtec on you
Re: (Shaun)
i checked the connectors and i cleaned them out when i plugged it back up i was still throwing code 17.
BTW the connectors were both clean there was no corrosion on any of them.
Re: (jaydm ferio)
ok guys i got a vss from my buddys b16 and when i drove my car my speedometer still did not work, do you think it is my harness plug?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio »</TD></TR><TR><TD CLASS="quote">listen out you might hear me smash vtec on you </TD></TR></TABLE>
buwhahahahahaha that is the most stupidest thing I've heard...smash vtec???? buwhahahahahaha
take it eas buddy dont hurt yourself there.
Re: vss problem (h22a_ej)
ok im having the same problem. 2 different vss's arent working. the bottom of the plug on the harness side looks a lil burnt. im confident thats my problem, and probably yours too
Re: vss problem (blackeg)
yea man i dont know, i changed the actual plug on the harness with another one and i still have the same problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio »</TD></TR><TR><TD CLASS="quote">yea man i dont know, i changed the actual plug on the harness with another one and i still have the same problem.</TD></TR></TABLE>
ohhh. hmmmmm.......
ohhh. hmmmmm.......
stehigs321
15
03-01-2019 05:16 PM
