O2 Sensors Help!!!!!!!!!!!
Hey whats up, i got a 04 civic and i am planing to take of the catalictic and redo the whole entire exuast. but when i do that i got the o2 sensors in the catalitic and in the headers. is there a way i can disconnect the o2 sensor so i wont get the service light. lets me what i can do thanks and if i put a air intake do i need to do anything about the o2 sensor
Re: O2 Sensors Help!!!!!!!!!!! (ibepimpedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibepimpedout »</TD></TR><TR><TD CLASS="quote"> lets me what i can do thanks and if i put a air intake do i need to do anything about the o2 sensor </TD></TR></TABLE>
WHHAAAAA?
WHHAAAAA?
u need a chip so the ecu will not look for the o2 sensors. just tap the new exhaust system and put the sensors back in , u will get good gas milage
Re: O2 Sensors Help!!!!!!!!!!! (Harassing Herbs)
You'll want to use the primary o2 sensor. That monitors your air/fuel ratio. It is possible to use an o2 sim to get rid of the CEL, but just know in your heart of hearts that you're slowly killing mother earth
what would you recomend me to do. cuase im was going to leave the 02 sensors out i guess. the place where they are going to do my exuast is probally going to leave them out. all there going to do is put a new pipe they bend.
Re: (ibepimpedout)
Before you do ANYTHING, research about what you're doing! You shouldn't go about changing things when you don't know what the hell any of it does!
You need to keep at least the primary sensor in and working, cuz it'll be pretty funny if your fuel system starts failing and you don't know it cuz your engine isn't monitered at all.
Lesson here: Don't "pimp your ride" just because MTV says it's cool.
Re: (ibepimpedout)
Did you read what i just posted? You at least NEED the primary o2 sensor in your header, it's ridiculously stupid taking out both.
I know you want the cheaper answer, so here it is: leave the primary one in and get a simulator for the second one. Try this: https://www.casperselectronics...honda
Hows that for a serious post to a retarded question?
Re: (ibepimpedout)
because you don't feel like using the search function, read the FAQ section from this website. It should explain most of your questions...
Yes your car is 0BD2, and yes you have to leave both sensors in..
http://www.o2simulator.com/
Lude_with_an_H22_Attitude
11-03-2005 02:22 PM
