Power mirror help
Power mirror help
Well my brother bought a used 1996 ex, everything works fine windows sunroof, but his mirrors don't. Was wonder what i should look for or test to see why it doesnt work
Re: (egtwincam)
fuses are still good and i switched the control still doesnt work how would u check the power? i used a volt tester on the end of the harness while i tried to move the mirror none of them get power, but im not sure if im testing it correctly
1 Post
Re: Power mirror help (l2agnar0k)
if both of them dont work Id say its likely a bad switch since you say the fuse is good. See if you can borrow someones switch or try yours on someone elses to see if its good.
Re: (95DxSi-R2)
I have the same problem in my 99 coupe, I took it in to my auto electric class and found that there was a short to my power wire for the power mirrors. U can bypass the wire to see if the mirrors work, if they dont then the mirrors are usually broken. The weak as shop that painted my car damaged my mirrors when they took it apart to get it painted. power mirrors for the coupes break fairly easily.
Re: (ueatdooki)
cnt be the switch because ive change it with a friends (his power mirrors work) ill have to check if power is going through because no power is going to the mirrors ill check this weekend thanks for the help.
shattachris
11
03-18-2013 07:18 AM
datssoled
07-30-2009 09:54 AM
