Re
Replacing the "Backing plate" of Trailing Arms and Rear Axle
on a 92 EG Si...
I want to replace the rear discs, pads, bushings and shocks. When I disassemebled the rear arms from the car, I noticed a part of the trailing arm is all rusted. The trailing arm itself is fine. But where the caliper mounting bracket mounts and rear axle is mounted to, there is a seperate "backing plate", which is all rusted. Now, I can't find the name or part# of the piece I need to replace. I have only checked a few sites and Honda's manual. This part resides on the outside face the trailing arm is attached to the trailing arm by four t-50 bolts accessible from the inside. What's is the name of this part? Will I be able to purchase it as a seperate? So far, I think my only option would be to replace the entire trailing arm. At $214 each, I would rather not. Any ideas or information would be appreciated. Mickey
Modified by martyr1391 at 4:55 PM 4/9/2005
Modified by martyr1391 at 5:14 PM 4/9/2005
Re: (litterbox)
Just behind the shield (34/35) and on the trailing arm (14/15), you will find the spindle where the hub rotates around. The spindle is attached to the trailing arm on a metal plate that is attached to the trailing arm with those t-50 bolts. It is that metal plate that is badly rusted.
That same metal plate provides mounts for caliper mounting bracket.
Modified by martyr1391 at 10:04 PM 4/9/2005
Re: (Aphelion)
If I can't order a replacement, that might be my only option...
Thanks everyone.
Cross thread..
https://honda-tech.com/zerothread?id=1207575
Modified by martyr1391 at 9:39 PM 4/12/2005
Thanks everyone.
Cross thread..
Graybeard327
Honda CR-V & Element
07-16-2017 06:42 AM
martyr1391
Suspension & Brakes
04-12-2005 08:37 PM
