question for d15 vtec owners
i have a jdm d15b vtec. ive heard of guys saying that running on the p28 causes the motor to run rich and that also leads to having to change your oil more often. i have to change mine about every 2 months because it really starts to get black. is there any thruth to this. also...is the only difference between the p28 and the p08 the 1 wire o2 (well..besides the fuel maps). would it be in my benefit to switch to a p08. ive heard you get a little more out of the d15b running it. truth or not. any know from experience?
Re: question for d15 vtec owners (a1320honda)
ive had my d15b vtec in my 93 coupe for a lil less than a year and im runnin a p28. So far its runnin perfect no smoke or nothin i change my oil every 3 months like usual . some times almost 4 months and it still only be about a half a qt. low...
I noticed that my d15b runs a little rich while using the p28.
As for the oil thing, I still change mine every 2000-2500 miles.
There is a little too much fuel, and the timing map is not correct with the P28 running the D15B. Since you already have the P28, just chip it with a P08 program with the 4 wire o2, ELD, injector test, and BARO sensor routines enabled, and the 112mph speed limiter disabled. If you need a chip kit or full installation, let me know.
Re: question for d15 vtec owners (Jim Truett)
black oil isn't bad oil. it just means that its been heated to a certain temperature, that's all.
you shouldn't change your oil just because it's black.
Re: question for d15 vtec owners (Mike K)
well i can definatly tell a difference in the way the car runs after a fresh oil change. it pulls harder and idles smoother. to cure this problem i can chip the p28 i know, but what about using a fpr and leaning it out a little?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda »</TD></TR><TR><TD CLASS="quote">well i can definatly tell a difference in the way the car runs after a fresh oil change. it pulls harder and idles smoother. to cure this problem i can chip the p28 i know, but what about using a fpr and leaning it out a little?</TD></TR></TABLE>
That never works properly. It's not like you need to lean it out a uniform amount. The fuel maps are different, and the D15B has a different torque curve than the Z6, so the maps aren't even that close. You would also be running on the less than ideal Z6 timing maps.
Re: question for d15 vtec owners (dnoredsi)
so what would be the best way to go about chipping my ecu, i have to use my car everyday and cant afford to send it out for a week. and i dont know of anyone in Spokane WA who can do it, so anyone know. sorry for such a noob question but ive never really dealt with ecu's yet.
http://www.pgmfi.org
http://uberdata.pgmfi.org/
Read around there - all the info is there, there's just a lot of it.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda »</TD></TR><TR><TD CLASS="quote">i have a jdm d15b vtec. ive heard of guys saying that running on the p28 causes the motor to run rich and that also leads to having to change your oil more often.</TD></TR></TABLE>
This is the biggest Crock Of ****, i have ever heard Alot of things cause a car to run rich.
Interestingly...
I did my first datalog today with my new JDM D15B. I was running a D16z6 based basemap to start with. The car idled at between 10-11 AFR!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnoredsi »</TD></TR><TR><TD CLASS="quote">GO CROME OR GO HOME</TD></TR></TABLE>
Learn how to spell or go home...lol
Re: question for d15 vtec owners (sohcvtec66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec66 »</TD></TR><TR><TD CLASS="quote">Learn how to spell or go home...lol</TD></TR></TABLE>
What did he spell wrong?
Re: (Blazin Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazin Civic »</TD></TR><TR><TD CLASS="quote">The motor runs fine on a p28...i did it for quite a while before switching to neptune.</TD></TR></TABLE>
well, i just want to be sure im getting the optimal fuel maps and whatnot. i know the p28 runs it pretty well, i mean my car pulls like a GSR with bolt-ons. but like i said, my exhaust is always covered in black soot, so its definatly running rich. i know i should be able to lean it out and make a little more power. i dont know if i can do that with a fpr, or if i have to rechip it?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">What did he spell wrong?</TD></TR></TABLE>
CHROME.....not "CROME"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec66 »</TD></TR><TR><TD CLASS="quote">CHROME.....not "CROME"</TD></TR></TABLE>
Sorry, but it's CROME. Cui's ROM Editor.
ouch thats a bit of a burn...
IMHO theres no point swapping your ecu. Do it once do it right, get a chip specifically made to suit your car.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">Sorry, but it's CROME. Cui's ROM Editor. </TD></TR></TABLE>
Dude you spell "chrome" like.... i have a nice set of CHROME rims..
Not ...crome is improper....plus Definitions of crome
* A long handled bent fork used for clearing weed on the Norfolk Broads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec66 »</TD></TR><TR><TD CLASS="quote">Dude you spell "chrome" like.... i have a nice set of CHROME rims..
Damn dude, CROME is a noun. It is the name of a piece of software used to edit Honda ROM files. When in this thread were we talking about chrome wheels or anything else chrome plated at all? Maybe we should ask John Cui to change his name and the name of his software to match convention.
More proof for you: http://forum.pgmfi.org/
Scroll down to the software section. Low and behold: CROME
