Engine Rebuild Questions D16Z6 DD Turbo
Hi everyone, just a noobie from Hawaii looking for advise on a planned D16Z6 build up for my '94 Civic Ex
I'm looking to due an extensive build up, forged pistons and rods, block resleeve, Crower Stage II turbo cam, SuperTech complete valvetrain, XAct street lite flywheel, and most likely a Edelbrock 1502(steet legal) or 1503 (open track-if I can find a good experienced tuner and a closer commercially available dyno-nearest one is over 100 miles away). The car is a '94 Civic Ex, suspension parts so far are: Koni Sports w/GC coilovers, ES master bushing kit, ST F/R sway bars, & Konig 15x6.5 Heliums. I have a set of weight scales being shipped to me for corner balancing the suspension.
What kind of boost range should I go for with 92 octane pump gas?
I have two long blocks, the original one with badly scored rod journals (ex wife ran it for several weeks with loud bearing knock!...part of the reason why I got the divorce ) which I could either try to find a used crank from a D16 (from what I have researced here at H-T, all D16s have interchangeable cranks or do some of them have different snout diameters?) or should I buy a remanufactured one.
Which replacement crank would be a better bet for a boosted build up, used or remanufactured?
The second long block I got was pulled from a rear ended wreck, has a block that is tagged with a REMANUFACTURED aluminum plate with about 40,000 miles on it, would this be a better shortblock for rebuilding and forget about the original block and replacement crank?
Would anyone care to look over my list of tools necessary for a good block reassembly and comment/add to it? So far, I have on my list of needed tools are:
1. Cam degreeing kit with dial indicator, test springs
2. Piston ring filer
3. ring compressor
4. Plastigauge (or should I invest in mikes and bore gauges)
5. Rod bolt stretch gauge
6. Height mike for valves/retainers/springs (what size?)
7. Torque wrenches
Aside from the torque wrenches that I already have, is it worth the investment or just pay to have the shortblock assembled professionally?
All comments and suggestions are welcomed as I want to do it right the first time!
Aloha and TIA!
3. ring compressor
7. Torque wrenches
Aloha and TIA!
greddy95ex
11
01-09-2009 10:46 AM
