my civic blows white smoke when i pop vtec??????????????????????
when ever i pop v tec i burn oil and white smoke comes out i did a compression test #1.160psi #2 150psi #3 160psi #4 160psi im not sure wat can be causing the car to be burnin so much oil i add some at least 3to 4 times a week only other thing i think it is is my valve guides ???????help
Re: my civic blows white smoke when i pop vtec?????????????????????? (REEMB18C1)
Search for burning oil and grab yourself a sandwich and read up.
A lot of peoples cars burn oil. Just check your oil levels whenever you put gas in and you should be alright.Good luck.
Re: my civic blows white smoke when i pop vtec?????????????????????? (S(J)O(D)L(M))
uhhh you said white smoke, which is coolant not oil, but it probably your valve guides are shot, and need to be replaced, but i would also check your headgasket as well as look in the coolant overflow tank to see if there is any oil in there
Re: my civic blows white smoke when i pop vtec?????????????????????? (Soccerking3000)
iight my coolant level is ok and there just antifreeze in my over flow the smoke doent come out my tail pipe unless im at like 5000 rpm and beyond
i know this may sound stupid, but were u drving in the rain when this happened? Because my EM2 does it in the rain. What happens is the exhaust gets hot when u rev like over 5g and the water spraying on it evaporates. Like under about 5g the pipes dont get that hot because of the minimal exaust flowing through. Thats what mine was, because i noticed it wouldnt do it when it was sunny out and dry roads.
Oh boy that sounded stupid, but sometiems problems are of the stupidest nature. Good luck figuring out what it is!
Re: (sickity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickity »</TD></TR><TR><TD CLASS="quote">actually it could be oil.....oil burns white smoke, gas burns black smoke, and a mixture of the two is a blueish color....</TD></TR></TABLE>No.
Coolant burns white, fuel burns black, oil burns a greyish color
Re: (rentacop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rentacop »</TD></TR><TR><TD CLASS="quote">No.
Coolant burns white, fuel burns black, oil burns a greyish color</TD></TR></TABLE>
ypu but oil can also burn the blueish tint...
Re: (sickity)
nah it happens in the rain and when eva i go over 5 grand when i put in my 6al and i hit the rev limiter smoke come out i got that set at 7 grand
Re: (REEMB18C1)
well first of all vtec motors burn oil while in vtec,as for it being white smoke you said you checked the overflow tank and there was no oil so its not the headgasket, i dunno man
Re: (MDJ IKNJ)
it is most likely ur rings, im getting my motor rebuilt because its doing the exact same thing. i bet ur rings are fried. mine only blows out a little bit and the guy gives me 3 months till my motor goes kahpoof. ur smoke is probaly a white-bluish smoke, cause white is definantly coolant and blue is oil. i wouldnt run ur car that hard or pop vtec that much, thats what i have to do and it is really hard
Re: my civic blows white smoke when i pop vtec?????????????????????? (EgRedSi)
whenever i 'pop' vtec it blows out whitish/blue, i just had cams installed.. stage 1. then all the problems come
Re: (Toolman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toolman »</TD></TR><TR><TD CLASS="quote">changing the gasket on a civic doesnt look too hard..</TD></TR></TABLE>
yeah, it's really not. but if it's piston rings that are gone. thats another story + another 400 bux.
