URGENT... PROBLEMS DROPPING THE TRANNY.
Re: URGENT... PROBLEMS DROPPING THE TRANNY. (solsi2000)
Prybar it appart.
Did you make sure to get all the bolts that are behind the motor area? Like around the bitch mount? I always end up forgetting one back there and its scary to get when the tranny is ready to fall.
Re: URGENT... PROBLEMS DROPPING THE TRANNY. (97civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx »</TD></TR><TR><TD CLASS="quote">trans is sitting on input shaft, pry slowly. It will come off. </TD></TR></TABLE>
don't lay underneath it when u do this either... i once saw some horrible pics of a nose from that.
Re: URGENT... PROBLEMS DROPPING THE TRANNY. (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">did you take the starter off?
if not...that is your problem</TD></TR></TABLE>
You don't need to take the whole starter off - not on a D-series anyway. You do however need to remove the lower starter bolt as that threads through the tranny and into the block.
Xemu
10-03-2006 10:16 AM
sleepyhamsterlx
03-16-2004 02:52 PM
