ITR 5 Lug Conversion onm 94 EJ Coupe?? HELP!!!
I have a quick question I am doing a 5 lug conversion on my 94 EJ Coupe... Well my stock shocks work with the ITR Brakes and control arms, for the front and rear... let me know asap... Everything I will need thanks...
Mr. Badwrench
Re: ITR 5 Lug Conversion onm 94 EJ Coupe?? HELP!!! (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">You will need ITR struts in the rear if you use ITR LCAs. You can only use your stock struts if you use the Civic LCA.</TD></TR></TABLE>
thanks for the clarification. when i did mine i used my lca's. so i got to keep my sispension.
be professional
Re: ITR 5 Lug Conversion onm 94 EJ Coupe?? HELP!!! (compwc18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by compwc18 »</TD></TR><TR><TD CLASS="quote">alright, so then the ITR and civic suspsension in the rear are both mouted differently.... correct?</TD></TR></TABLE>
Yes, but it doesn't matter because you don't need the ITR control arms. All you need are the front knuckles and rear hub assemblies.
.jacob
08-19-2003 10:23 AM
