TRACK 1/4 mile
TRACK 1/4 mile
so i ran at the track for the first time tonite.my setup is a
jdm d15b
3" intake
megan racing header
2.75" aerospeed exhaust
test pipe/race cat
vafc-untuned
short shifter-tenzo
jdm p08 d15b ecu-shifting at 7,300-7,400
UR crank pulley
msd ignition
also gutted from front seats back
1st run ever at the track- didnt launch
R/T... .497
60... 2.621
330... 6.921
1/8... 10.422
MPH...69.91
1000...13.448
1/4 ... 15.984
MPH... 88.97
2nd run- didnt launch
R/T... 1.518
60... 2.539
330... 6.803
1/8... 10.275
MPH...70.56
1000...13.281
1/4 ... 15.807
MPH... 88.99
3rd run- didnt launch
R/T... .719
60... 2.522
330... 6.754
1/8... 10.228
MPH...70.51
1000...13.235
1/4 ... 15.754
MPH... 89.51
UPDATE - 15.403 at 88.91mph with a 2.254 60ft 4-15-05<U></U>
my tires were at 40psi and i got a little bit of wheel hop off the line. Just need some advice on what i need to improve on to make my time better and any mods i should do? Im thinking about Skunk2 IM
Modified by slotec at 8:27 PM 4/10/2005
Modified by slotec at 8:50 PM 4/15/2005
Modified by slotec at 9:14 PM 4/15/2005
jdm d15b
3" intake
megan racing header
test pipe/race cat
vafc-untuned
short shifter-tenzo
UR crank pulley
msd ignition
R/T... .497
60... 2.621
330... 6.921
1/8... 10.422
MPH...69.91
1000...13.448
1/4 ... 15.984
MPH... 88.97
R/T... 1.518
60... 2.539
330... 6.803
1/8... 10.275
MPH...70.56
1000...13.281
1/4 ... 15.807
MPH... 88.99
R/T... .719
60... 2.522
330... 6.754
1/8... 10.228
MPH...70.51
1000...13.235
1/4 ... 15.754
MPH... 89.51
Re: TRACK 1/4 mile (slotec)
try launching?
i mean **** you are complaining about your times and you arent even driving to your full extent. the only thing that is gonna make your car faster if you are rolling off the line is more horsepower.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slotec »</TD></TR><TR><TD CLASS="quote">
i got a little bit of wheel hop off the line. </TD></TR></TABLE>
is that possible? it would seem like u could only get wheel hop from launching
Re: TRACK 1/4 mile (93ejay1)
like i didnt launch but i had my foot easing off the cluctch ready to go. ABout taking bnolt on GSR;s i ran a 96 GSR with i/h/e vafc ignition, cams and cam gears and i was on its fender, never pulled on me.
try lowering your psi to about 30 or lower, rev it to about 5-6k and slip the clutch. thats what i do and i pulled a 2.1 60 ft in my z6 W/ A CAI
Modified by 93ejay1 at 10:42 PM 4/11/2005
i lowered it to 22psi and i was going to try launching the next go. it was my go at the light and they wouldnt let us go because it started drizzling. Also if i launched at 5-6 wouldnt i spin like alot, remeber its a single cam and my rev limiter is only 7500rpms.
I thought a perfect R/T was a .500, anything below that was a redlight. Or did you redlight on that run?
Anyways, work on your 60'. You get those times down, you will get your 1/4mile times down.
Re: TRACK 1/4 mile (SOHC4life 96)
im not sure if .500 is perfect if it is then i was close on the first run. ive been told by soo many people that i should launch at different rpms. some say 3-3500 some say 5-6000rpms/
it doesnt matter the reaction time, your reaction time could be 10 minutes and you could still run 10's. But you shoulda launched from around 5k and slipped the clutch, but good job you would take out the EM1's
Re: TRACK 1/4 mile (Soccerking3000)
.500 is perfect rt at some places and at others its 0 or whatever. if you dump the clutch do it at 3.5k and if u slip the clutch do it at 5-6k. i use to dump the clutch at 3.5 but i would still get wheel hop so i stopped and now i slip it at around 5500.
Re: (darkshadowcivic)
check my sig.
im running a launch at 5700, 20-23 psi in the tires depending on track. cutting consistent 2.1 60ft with a best of 2.06. im also using the y8 tranny. what tranny r u running. thats the best thing ive done to improve times. i turned a personal best last year of 14.8 and that was still on the oem exhaust manifold and exhaust.
launch!! and run less tire pressure, like way less. I run 18-20psi for consistent 2.0 60ft times with street tires. Even better get some semi slicks or even full slicks if you are allowed (i dont know how the rules work over there)
Re: (a1320honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda »</TD></TR><TR><TD CLASS="quote">ive heard running that low (18-20)will cause you to lose mph in the traps. not flaming, just wondering</TD></TR></TABLE>
I tryed 20psi yesterday from 24psi that I was running last week and I ran the same times, only at 90mph instead of 93 last week. There are many other factors that come into play though so I dont know if it was just the lower PSI that did it.
my times were horrible.....i have a 1993 civic si hatch with a jdm b16 lsd...itake exhaust...CEL for tps and im runnign the stock p28.....i ran a
r/t=.198
60'=2.425
330=6.839
1/8=10.534
mph=67.60
1000=13.637
1/4=16.238
mph=85.74
dont feel bad......i need to get my ecu chipped and my tps...i just wanted to show my embarrassment...
r/t=.198
60'=2.425
330=6.839
1/8=10.534
mph=67.60
1000=13.637
1/4=16.238
mph=85.74
so you finally took your car to the track. it took you long enough. thats not bad at all for what you have. but i can't believe you didn't launch, i've seen you run on the street and you always seem to drop it at 3500 or something like that. o yea who was the gsr you ran? just wondering. neways keep workin on it and you might beat me one day. LOL
-Jordan
-Jordan
NASIOC.com
Re: TRACK 1/4 mile (Swapped_EG)
What you need to do is rev your **** up to 3k, and when u see the second to last yellow light on the "tree" you need to leave on that... Get your RT down to a .1
My last run was a 14.8 with 60 shot of spray... Worst thing i could of ever done... Now im rebuilding my damn motor... Oh, and i have a d16y8... well had... The sleeves are now blown... oh wait what sleeves i dont see any =P
