fuel pressure on a d15b vtec, what do i set it at?????
ive got a d15b vtec with all the bolt ons. i had heard that using a p28 to run a d15b runs it rich, so can i use my fpr to lean it out, or do i need to go to the p08 ecu? what would be a good way to set my pressure. i know their not very accurate but im also going off my a\f gauge which is always burried at rich at wot. the fuel pressure gauge reads 38ish at idle and 41-43 at wot. so should i just lean it out?
how rich is it running at WOT? because it should be running rich around 12-12.5:1. Many people think that engines should always run at 14.7:1 which is not the case! Personally i would rather be running slightly richer than leaner... far less problems
Re: (mr.sky)
well, my a\f gauge pegs at rich, and after a day of hard driving my silencer on my exhaust is covered in black soot. so id say pretty rich
Location: hittin corners so hard you can taste my rims..
Re: (mr.sky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.sky »</TD></TR><TR><TD CLASS="quote">how rich is it running at WOT? because it should be running rich around 12-12.5:1. Many people think that engines should always run at 14.7:1 which is not the case! Personally i would rather be running slightly richer than leaner... far less problems</TD></TR></TABLE>
from what ive heard over the years.
downhill, no throttle.. 15.0 A/F
cruizing, slight throttle.. 14.7 A/F
wide open throttle all motor.. 13.5 A/F
wide open throttle turbo >10 PSI 12.0 A/F
and anythign over 10PSI down to 10.0-11.5 A/F
so if your getting 12.0 all motor, i can bet money thats too rich. your just loosing power then.
Re: (Built B16A)
thnks for the response, but im not sure how that really helps me. im just learning the fuel side of things. so about where should i set my fuel pressure?
99TurboFerio
04-07-2005 04:37 PM
