EG how do I loop the power steering system?
Recent swap , didnt hook up the power steering pump....now I want to just loop the system so that I can remove the pump.
How do I do it ?
anyone done a write up on this, I searched the site and found nothing.
How do I do it ?
Re: EG how do I loop the power steering system? (knowles_101)
search harder there is a kit for sale on here to do it right. you cant just stick them all toghther the system needs to breathe. as for me i just took off the lines a left them open and i have no problems.
Re: EG how do I loop the power steering system? (e jay one)
Yeh I dont want to buy a kit, there must be a way to do it without the kit....Anyone done it?
keep power steering! just take off the belt when you race but yeah there are alot of topics on this forum
Re: EG how do I loop the power steering system? (patastinky)
reviving this thread. Searched around and couldn't find a kit. I know that the tutorial in the faq doesn't work for 92si's because the whole power steering tubes look completely different. I guess because it has all of these wires that extend out to the front of the car. Supposedly some type of cooling? duno.
a kit or a tutorial on a EG would be cool! anyone?!
Electrician
https://honda-tech.com/zerothread?id=462824
Gives you an idea.
https://honda-tech.com/zerothread?id=184202
Another.
Search the Archives.
Gives you an idea.
Another.
Re: EG how do I loop the power steering system? (eg6junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6junkie »</TD></TR><TR><TD CLASS="quote">keep power steering! just take off the belt when you race but yeah there are alot of topics on this forum</TD></TR></TABLE>
i do that but does just taking off just the belt actually do anything?
Electrician
Re: EG how do I loop the power steering system? (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">i do that but does just taking off just the belt actually do anything?</TD></TR></TABLE>
The engine isn't spinning an extra pulley. So yes, it does. Removing the rest of it is just for weight reduction.
Re: EG how do I loop the power steering system? (Dimitri_EG8 a.k.a. Dimi)
Exactly, and if you're going for weight reduction, you will probably want to get rid of the power steering rack for a manual anyway.
okay so from what i've been reading some people just squeeze off the extra 2 lines that are on some of the power steering setups that aren't like the power steering racks in the tutorials?
Does someone know for sure what those extra hard lines are for? I've heard some say theyre for cooling the fluid and i've heard some say its for speed sensor?
Re: EG how do I loop the power steering system? (Plugg'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plugg’d »</TD></TR><TR><TD CLASS="quote">reviving this thread. Searched around and couldn't find a kit. I know that the tutorial in the faq doesn't work for 92si's because the whole power steering tubes look completely different. I guess because it has all of these wires that extend out to the front of the car. Supposedly some type of cooling? duno.
a kit or a tutorial on a EG would be cool! anyone?!</TD></TR></TABLE>
i have not found anything about the 92 si hatche's either....i got a 92 si with 2 line's going to the cooler ------so i have three line's that i had to remove... but no-one has any write up's on it....every-one keeps referring to some type-r forum...it's complete different ...bump fo some help.....
on my old EG i just took the 2 lines. and cut them. put some fluid in there. and had a T fitting i put the 2 PS lines on there. and put a breather on the top of the T. held up fine. just put some fluid in there every 10k miles of driving.
Re: (FlatBrokeHatch)
Unless you change it out for a manual rack and pinion steering assembly, please keep the power steering pump. The pump also circulates the fluid through a cooler. I don't think it's a good idea to not cool the fluid or even not circulate it. The pump adds little resistance to the engine. If weight reduction is what you want, then you should get the manual steering assembly.
Global Moderator
Re: EG how do I loop the power steering system? (Deemeetree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree »</TD></TR><TR><TD CLASS="quote">The engine isn't spinning an extra pulley. So yes, it does. Removing the rest of it is just for weight reduction.</TD></TR></TABLE>
Wrong.
I removed the rest of the system for the increase in steering feedback. Not everyone is a straightline drag racer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpkelly »</TD></TR><TR><TD CLASS="quote">Unless you change it out for a manual rack and pinion steering assembly, please keep the power steering pump. The pump also circulates the fluid through a cooler. I don't think it's a good idea to not cool the fluid or even not circulate it. The pump adds little resistance to the engine. If weight reduction is what you want, then you should get the manual steering assembly.</TD></TR></TABLE>
Horrible advice.
The manual rack has a slower ratio than the power steering rack.
Also running the power steering rack looped does not harm the system in any way.
Wrong.
Horrible advice.
