what mounts do i use for a sir 2 into a 1994 honda civic ex
can i use my regular mounts for my sir 2 swap on my 1994 5 spd honda civic ex?
Location: With my POS D15B2, Whereever whenever, United States
Re: what mounts do i use for a sir 2 into a 1994 honda civic ex (zero-one)
all mounts work except the t mounts and the front torque mounts i believe
94-01 integra rear 'T-bracket-
94-01 Integra Upper 'Timing-Belt' Mount
You need An Integra or B16 A/C Bracket.
Everything else you can use your stockers
Re: what mounts do i use for a sir 2 into a 1994 honda civic ex (OneFiveAlive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OneFiveAlive »</TD></TR><TR><TD CLASS="quote">
You need An Integra or B16 A/C Bracket. </TD></TR></TABLE>
To be more precise, a 1995 Del Sol VTEC A/C bracket. If I am not mistaken it's the P54 Bracket.
Re: what mounts do i use for a sir 2 into a 1994 honda civic ex (Lynx Bus Type R)
you can use that one too...im running a p72 bracket in my 95 hatch
Re: what mounts do i use for a sir 2 into a 1994 honda civic ex (eg6hatch94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6hatch94 »</TD></TR><TR><TD CLASS="quote">stock should work.. worked for my cousin </TD></TR></TABLE>
If i remember correctly, the d-series bracket will not bolt onto a B block
1 Post
you will need all b series mounts except for the upper tranny mount. that is the only one you can reuse. If you want to retain your a/c then use a p54 delsol dohc vtec a/c bracket.
Re: what mounts do i use for a sir 2 into a 1994 honda civic ex (hatchi)
is there a real difference between the stock mounts and aftermarket mounts
blasterman87
06-05-2009 09:51 PM
