knock sensor code help??????????????????????????????????????????
Old Nov 26, 2005 | 02:22 PM
ppl talk bout my old name's Avatar
Default knock sensor code help??????????????????????????????????????????
i am throweing a knock sensor code but im stilll hiting vtec wht the expletive is up with that and im also havea code 2 witch is o2 should i change it and my ks is starting to freak me out cuz im suffing massive power loss on my b16a so im not driving it
Old Nov 26, 2005 | 03:40 PM
Lord Helmet's Avatar
Default Re: knock sensor code help?????????????????????????????????????????? (ten second crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ten second crx &raquo;</TD></TR><TR><TD CLASS="quote">i am throweing a knock sensor code but im stilll hiting vtec wht the expletive is up with that and im also havea code 2 witch is o2 should i change it and my ks is starting to freak me out cuz im suffing massive power loss on my b16a so im not driving it </TD></TR></TABLE>
mods done to it, blah blah blah. give us details about the enigne. help us help you.
Old Nov 26, 2005 | 04:11 PM
Haltom Hatch's Avatar
I've always been under the impression that throwing a knock sensor code will put your fuel and ignition curves in safe mode meaning (no performance) I am pretty sure you would still be able to hit vtec but if you are detonating you might want to find out why and correct it before you have to replace a bearing and or con rod.
Old Nov 26, 2005 | 04:51 PM
dohcMONSTER's Avatar
Default Re: (Haltom Hatch)
it retards your timing when you throw a knock sensor code. get a chipped p28 and eliminate the knock sensor so you dont throw the code anymore
Old Nov 27, 2005 | 02:12 PM
Default Re: (dohcMONSTER)
i have a stock b16a with a pw0 ecu and a p28 wont work with the obd0 motor unless i get the harness witch i have and the ecu is a piece of **** i hate that program i blow to much **** up with it so should i just have it replaced or chiup the pw0 ecu
Old Nov 27, 2005 | 02:51 PM
duggy's Avatar
Hrm why don't you actually try to find out if the knock sensor is actually DOING it's job and detecting knock?
Old Nov 28, 2005 | 10:27 AM
Default Re: (duggy)
how do i determin if it is actulay doings its job how can i tell
EF_FEVER
Feb 22, 2007 12:32 PM
bokals
Jan 20, 2007 11:53 PM
Grip
Jul 13, 2004 08:43 AM
99spanishGT
Mar 26, 2004 12:40 PM
TRhatchCRAP
10
Aug 10, 2003 11:52 AM
