my car still idle so high...2k start up, 1k warm up
my car idle very high, 2k when its cold and 1k when its hot, 1.5 average when i stop and go. i check my timing, everything is good. my cam gear did jump a few teeth but i correct it already. what else could be the problem?
Re: my car still idle so high...2k start up, 1k warm up (deadend9009)
yea when its cold out and i start my sol in the morning it idles at 2k then once its a lil warm it drops to a lil less then 1k
Solbros Owns Me
Re: (lv6l)
reset idle speed....
1. warm up engine
2. Turn off all loads and disconnect IAC
3. Adjust idle screw so engine idles around 480
4. Shut off car, reset computer and plug in IAC
5. Start car and let it idle for 5 minutes
Should be cool after that, unless you got mechanical problems
1. warm up engine
where can i find the plug to disconnect the IAC. also, i have an rpm off an ex cluster and i see the number 1 and the number zero with a line right above it. is that little line(close to the bottom line)500rpm or 0rpm?
ok, my idle seem to be ok, but now i have a bigger problem. i notice when i was waiting for my car to warm up, my fan neve turned on. so i thought it was slow, i finish up the process of what Evs-One told me to do than was suprize it fixed my idle, but than i look at my temp and it was about to overheat! i dont know when my fan stop working but i was driving about an hour earlier and the needle didn't go anywhere near the middle. i had the temp in the car's climate control **** on hot when i was driving but did not turn on the climate fan. i didn't see the neddle go up on the temp gauge, but now my car's radiator fan wont go on and my car is close to overheating, needle goes close to up high and i stop and here i am now on honda-tech. asking you guys. HELP
Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l »</TD></TR><TR><TD CLASS="quote">where can i find the plug to disconnect the IAC. also, i have an rpm off an ex cluster and i see the number 1 and the number zero with a line right above it. is that little line(close to the bottom line)500rpm or 0rpm?</TD></TR></TABLE>
that little line right above the zero is 500. some people mistake it for 100 or 200 and think that they are idling lower than they actually are
This is what I did when I had a 3k cold idle and a 2.5k warm idle.
1. Take off your TB.
2. Under your TB should be your FITV.
3. There are 3 screws holding that on. Unscrew it.
4. There is a cap on the FITV with two Phillips screw. Take that off.
5. Inside, there is a white diaphram, if it is backed out, turn the white screw with your hands in a couple of turns. Keep doing this until your idle gets better.
Solbros Owns Me
Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l »</TD></TR><TR><TD CLASS="quote">yeah all fuse are ok looking and i plug everything back.</TD></TR></TABLE>could be the fan relay, fan switch or motor.Jump the motor straight off the battery and see if it works. If it does, you know it's either a fuse/relay/connection/sensor, etc
oh, thanks you guys, my radiator fan works now, it turn out, ther was a harness near the dizzy that was unplug. but as i was raeding, duggy post his directions to check out the FITV. i have tried doing that before, i took off the throttle body and stuff and can't seem to find the FITV. could my car be missing this? would a car run if it was missing this? what does the FITV look like and how big is it? maybe i'll take it off again and give it another shot.
DaX
10-24-2018 04:56 AM
