REMOVING TRANSMISSION, NEED HELP ASAP
whats up, im removing my b16 hydro transmission right now. i have all the bolts and accessories off and it appears as if nothing is holding the transmission on to the engine but i can't get it out. is there some secret thing i don't know? any help would be much appreciated. thanks.
Unceasing Measure
Re: REMOVING TRANSMISSION, NEED HELP ASAP (mintscorpion)
Check again for bolts - on both sides of the bellhousing. Is the starter off? How about the inspection cover? Bracing? Have you tried prying at all (gently)?
make sure all the mount bolts/tranny bolts are all off and you need to pry it out with a crowbar
Re: REMOVING TRANSMISSION, NEED HELP ASAP (jdmboi86)
Don't forget the stabilizer bolts... those 2 "legs" that come off the block, they're 14mm... I forgot those on my first tranny swap.
averyvm
08-07-2007 09:57 PM
inspyral
10-08-2002 05:09 PM
