apexi ws2 help
apexi ws2 help
so i got my apexi ws2 installed and the flange after the muffler is hitting the metal... its about a centemeter away my car is a 00 civic coupe pix or advice 2 fix would b great
Re: apexi ws2 help (JDMChrisEK)
the flange after the muffler? it goes from engine, to cat, to muffler to outside air. i got the ws2 on my turbo 00 ex, no problems, could you take a pic?
Re: apexi ws2 help (bluemax189)
well i got myne in 3 pieces since it replaced the cat the mid and cat replacement are fine... its the flange piecing together the muffler and middle pipe thats hitting
yea post up a pic or two if you could... might be able to help better.
I have the WS2 on my 96 EX and there are a few pics of it in my cardomain page (link in sig)
I can take more pics too if you would like for reference.
Re: apexi ws2 help (Slow EJ8)
this is the pic
the thing behind it is a rubber hanger i tried 2 put between it and fasten but it fell off obviously but that is the pipe behind the muffler and that flange there is the problem its close as helll
i know when i installed my apexi n1, the S pipe was hitting the gas tank, and u can hear it vibrate, so i flipped the S piped the other way, now its kew, more clearance
Re: apexi ws2 help (cybergreencivic)
you can also loosen up the spring bolts, tighten them in a little at a time at each side, if that doesn't work, get a pry bar, and bend the hanger a lil so you get some clearance...i had the same problem with my WS2 and i did that to correct it
blindsk8er1013
09-08-2008 08:05 AM
