jdm h22 vtec pressure valve issue (I SEARCHED)
B A N N E D
I have searched for a few days now and i have tried everything. I checked all of my connections and the black wire is grounded to my thermostat housing like everone says and the blue/blk wire is connected to d6 through the stock wire loom. I also changed my entire vtec solenoid and pressure switch the code still pops up. I have cleaned every screen there is i have also tried another ecu.
What else can i do or is there some type of way to bypass this?
Setup: jdm h22, chipped ecu that all the info thats relative to this issue.
You have enough oil? Is your speedo working? The reason I am asking that is if you do not have enough oil, VTEC will not kick in.
If your Vehicle Speed Sensor is not working, then you will not have VTEC either.
What kind of chip is it?
B A N N E D
I put my car in the shop and come to find out my crankshaft was shot. They changed my oil pump and the psi was @5 so my crank is at another shop getting polished and etc so hopefully everything will be good this week. I will keep everyone updated.
B A N N E D
Re: (kaoss_11)
pressure fixed still throwing code 22. Has anyone else had this issue I have searched through many threads and still nothing.
Re: jdm h22 vtec pressure valve issue (kaoss_11)
bump for more info.
Im having the same problem and I aslo had a low oil pressure problem due to bad rod bearing. now fixed and still throwing the same code
tbgallant
08-16-2013 10:41 PM
Bimmerman
06-15-2005 05:23 PM
