car starts then dies! need help
Old 11-27-2005, 09:51 PM
dek1mfk's Avatar
Default car starts then dies! need help
i have a 92 civic dx hatch n i swapped in a 93 b18a and everything is fine except for wen i start it it starts right up then dies. If i hold the gas and rev it a lil to like 4k for bout 15 seconds n let go it idles perfectly after that. What would cause this? i thought it could be the gas thats in there because the car was parked for 5 months b4 the swap or it could be because i took of the dashpot thing that the 90-93 integras have on the throttle but it got lost so i cant put it bak and finnd out. if anyone can help please let me know what it could be?
update ok well i switchted the plugs on the map sensor frum the firewall to the tb n now it starts with no cel, but now if i tap the gas quickly the car studders n dies, and if i slowly start pressing the gas i cud go all they way 2 redline as long as i dont do it 2 fast. Any one have any ideas?
Modified by dek1mfk at 6:48 PM 12/31/2005
Old 11-27-2005, 10:11 PM
BluCivicDriver93's Avatar
Default Re: car starts then dies! need help (dek1mfk)
sounds like IAC (idle air control) to me make sure it is plugged in... you should be able to find a pic of where it is if you search
Old 11-28-2005, 10:39 AM
dek1mfk's Avatar
Default Re: car starts then dies! need help (BluCivicDriver93)
yea its plugged in and it is new. bump for more answers
Old 11-28-2005, 10:42 AM
ck123's Avatar
I have the exact same problem on my car!
i have to rev it up to 3k rpm in order for it to stay on when idle
heres my thread
https://honda-tech.com/zerothread?id=1446220
some guy said its a fuel pump relay problem
Old 11-28-2005, 10:44 AM
ck123's Avatar
im going to bring my car to my cousins shop and ask what the problem is and ill reply back with what he says
Old 11-28-2005, 11:07 AM
d16rice's Avatar
Your cam timing might be off a bit (skipped a tooth or something)
I had a similar problem a while a go right after changing my timing belt.
One easy way to check is if the throttle response is a bit sluggish.
Old 11-28-2005, 11:32 AM
2000civicsi's Avatar
I had the exact same problem on my car after i cleaned the IAVC.
Then I opened the radiator cap for about a min, closed it and she started with no problem. Guess u need to bleed the system. hope it helps
Old 11-28-2005, 12:38 PM
dek1mfk's Avatar
Default Re: car starts then dies! need help (2000civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ck123 &raquo;</TD></TR><TR><TD CLASS="quote">im going to bring my car to my cousins shop and ask what the problem is and ill reply back with what he says</TD></TR></TABLE>
thanks let me know wat he says.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi &raquo;</TD></TR><TR><TD CLASS="quote">I had the exact same problem on my car after i cleaned the IAVC.
Then I opened the radiator cap for about a min, closed it and she started with no problem. Guess u need to bleed the system. hope it helps</TD></TR></TABLE>
ill try that see if it fixes the problem
Old 11-28-2005, 12:50 PM
Andres-eh2's Avatar
My car did the same thing when i did a 93 b18a1 also. The MAP sensor was bugging out. Replaced it and reset the ECU and the code went away.
Old 11-28-2005, 01:37 PM
dek1mfk's Avatar
Default Re: (Andres-eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">My car did the same thing when i did a 93 b18a1 also. The MAP sensor was bugging out. Replaced it and reset the ECU and the code went away.</TD></TR></TABLE>
ill try that howm uch did u pay for the map sensor?
Old 11-28-2005, 02:08 PM
civic_driver's Avatar
when you hold the gas pedal you're affecting air and fuel... if it was the main relay the car would just die... my car dies the same way when it's very low on gas and pump can't keep the pressure up...so make sure you got enough gas.... if that's not it, i would check the fuel filter and injectors... make sure they're clean.... then i would check vacuum... if the motor isn't getting enough air to breathe, it will die especially when cold... is the coolant bypassed? if so, and you live in a cold area, that's most likely your problem... the IACV freezes up in cold weather not allowing air to get in and keep the motor RPMs high
Old 11-28-2005, 09:20 PM
dek1mfk's Avatar
Default Re: (civic_driver)
so u guys dont think the old gas in the system has anything to do with the problem?
Old 11-28-2005, 09:29 PM
Andres-eh2's Avatar
I didnt pay anything since I got one with the b18 and had one from my sohc
Old 11-29-2005, 04:10 PM
DB1_559's Avatar
mine did this to i had to with untill my cel light comes on and let off the gas and then perfect but i think it was my ecu untill my p28 came in it started just fine
Old 12-01-2005, 10:58 PM
dek1mfk's Avatar
Default Re: car starts then dies! need help (jdmboi86)
ok ill try another ecu, ne more suggestionz?
Old 12-02-2005, 09:47 AM
dek1mfk's Avatar
bump
Old 12-03-2005, 02:10 PM
dek1mfk's Avatar
up!
Old 12-21-2005, 08:41 PM
dek1mfk's Avatar
sorry 2 bring it back from the dead but i tried everything in this thread so far and nothing seems to help, any other ideas as to what it could be causing this?
Old 12-21-2005, 10:08 PM
FalkenSiR's Avatar
This problem happens all the time... search some, you should find lots of threads to keep you busy... it's always something different....
» Search Results
Your search for starts then dies returned 17 results.
Old 12-30-2005, 08:43 PM
dek1mfk's Avatar
Default Re: car starts then dies! need help (fast88std)
Old 12-30-2005, 09:08 PM
EG2Driver's Avatar
2000civicsi quoted the above....could it be that if im low on coolant that would do it?
z1p
z1p's Avatar
i also want to know this, clean the iacv, works for a couple days but now the problem is back.
Old 12-30-2005, 09:15 PM
dek1mfk's Avatar
Default Re: (z1p)
i jus want to kno what would cause it to bog out n die wen i tap the gas quikly but if i step on it slowly i cud bring it 2 redline wit no problem...
Old 12-31-2005, 05:46 AM
dek1mfk's Avatar
Default Re: (dek1mfk)
ne one.........
Old 12-31-2005, 02:45 PM
dek1mfk's Avatar
ttt need help this is my dd TIA
Quick Reply: car starts then dies! need help
