What axles for CTR 5 lug w/ D series
I've been searching, because I know its been covered before. I just cant seem to find it.
The combo:
93 Civic Si
D15b7
CTR 5 lug
the question: how do you do the axles?
Regular D series axles with changed outers?
Or is there a certain combo that works?
The combo:
93 Civic Si
D15b7
CTR 5 lug
Re: What axles for CTR 5 lug w/ D series (JUN EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 »</TD></TR><TR><TD CLASS="quote">I've been searching, because I know its been covered before. I just cant seem to find it.
The combo:
93 Civic Si
D15b7
CTR 5 lug
Or is there a certain combo that works?</TD></TR></TABLE>
would not the stock D seies work? I JUST did this conversion on a vx with stock engine. They worked fine.
The combo:
93 Civic Si
D15b7
CTR 5 lug
Re: What axles for CTR 5 lug w/ D series (Hybrid93Eg)
The axel spline is the same. You should be able to just do the conversion and use your axels like^ said.
Re: What axles for CTR 5 lug w/ D series (BigBlockH22atch)
I dont think it would work.
Actually, Im pretty damn sure it wont work.
Back in the day I got a set of stage 2 axles from DSS for my K20 swap, the spline count on the outers was wrong. I believe it was 28, and I needed 27.
They gave me axles for a standard EG, not for CTR. I recently had my motor taken out for smog reasons, and the guys who did it took off my 5 lug in the front because they said the axles dont work. So now I am confused.
Location: With my POS D15B2, Whereever whenever, United States
Re: What axles for CTR 5 lug w/ D series (BlueIntegraBoy)
It depends whether your 5 lug setup is USDM or JDM.
JDM have different axles, as opposed to USDM which D and B series axles have teh same spline i believe
Re: What axles for CTR 5 lug w/ D series (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda »</TD></TR><TR><TD CLASS="quote">It depends whether your 5 lug setup is USDM or JDM.
JDM have different axles, as opposed to USDM which D and B series axles have teh same spline i believe</TD></TR></TABLE>
CTR = JDM
which uses 32mm axle nut as d-series with same spline.
CTR = JDM
Re: What axles for CTR 5 lug w/ D series (JDMisGOOD)
how about this. There is a guy on here with a ctr sus set up on his dx hatch with a single cam in it and stock axels. His name is Aquafina.
Re: (an2ny888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">ctr (b16b motor) will work fine with d series axle. jdm itr will not work.</TD></TR></TABLE>
lol what?? english 1101 owns you I think you meant something else
Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">
lol what?? english 1101 owns you I think you meant something else</TD></TR></TABLE>
what don't you understand about my post? care to explain?
jaerikd
10-03-2009 06:03 AM
SoCal EJ1
01-30-2006 12:30 AM
RhdRicheeee
11-21-2005 04:06 PM
