Solid motor mounts
Solid motor mounts
Is there a "Home mechanic " way of making SOLID motor mounts?
I have Energy suspention mounts and I plan on having some power here shortly, figured Solid motor mounts would be the best for the power I plan on making!
1 Post
Re: Solid motor mounts (zx2gotboost)
What you can do is clean your stock motor mounts real well and then use some caulk in them with the MM inserts. They will stiffen them up a little bit.
Also which mounts do you have? The sports one or the race ones? If you get the race ones they are a bit stiffer.
Re: Solid motor mounts (aalb1)
Actually, I have the inserts, not a full mount, you slide the polyureathane insert in ur stock mount....... There RED. Thank you!
Bbasso
03-04-2005 05:48 PM
