Clutch Pedal Sticking.
Master cylinder was leaking, replaced that. A few weeks afterward, the car would engage, but the pedal would be stuck after the catch point. I replaced the slave and bled it, still didn't fix the problem. What is wrong here? It's starting to drive me crazy.
Re: Clutch Pedal Sticking.
The clutch is a fairly simple system. Try starting at one end and work your way to the other checking everything along the way. Isolate and check each part:
If you disconnect the pedal from the mc does it move freely? mc and fluid good? crimps or kinks in the line? slave cyl good? fork move freely?
