Need help/suggestion with b16 timing belt
ok, so i decided to installed skunk2 cam gears on my b16a2. already have sk2 tuner cams in motor. after i installed cam gears and put belt back on, my issue is the timing belt is too loose on the intake side even after i tighten the tensionor bolt.
any tips/ suggestions on how to solve this issue without taking the crank pulley off and redo the belt like you're changing/installing a new timing belt?
thanks
thanks
