shifting into 2nd problem...
got a 98 civic hatch all stock d16y7 and rebuild 5 speed tranny.
my issue is when say going around a 90ish degree turn going about 25ish if i try to just push in the clutch and drop from 3rd to 2nd one of two things happens.
1 either i get totally locked out of 2nd it just wont let me in. it wont grind or anything the sifter just wont go in at all.
2 or if im closer to the 20mph mark ill feel a click and it will go half way in than a 2nd click and its finaly in 2nd and i can go.
but if i coast the corner in neutral and then clutch in and go into 2nd its fine. is this a scynchro problem or some kind of linkage problem or what.
Re: shifting into 2nd problem...
Try and see if you linkage isnt hitting off something. If not honda and their infinite wisdom didnt stake the countershaft bearing and that likes to walk out and lock you out of second. How many miles on the trans?
no i guess it wouldn't hurt to try.
Or slip them a 50 and see if they will fix the issue.
