b16 misfire at low rpm..need help
hello guys,
yesterday suddenly my b16 (si 00) started somehow hesitating at rpm range 2-5 K it sounded like a machine gun.
It is like a very fast cutoff.
The below parts were replaced since 6,000 miles:
-spark plug
-sprak wires
-rotor
-distributor cap
Could it be a bad coil or ICM ?
anyone had similar issue?
thx
-spark plug
-sprak wires
-rotor
-distributor cap
thx
Re: b16 misfire at low rpm..need help
Same problem... I replaced the coil pack, plugs, wires, diz interals, injectors, fuel filter, cap, rotor and fuel pump to find out that after none of it worked and three mechanics couldn't figure it out, I did a compression test and the valves were shot. Crazy part is it ran for eight months before it really started to act up. It would just misfire once in a while and then be fine. Do a compression test just to weed that out before you spend more money.
willyboyK20
13
07-31-2003 12:43 AM
