Coolant leak from under throttle body
Old 04-23-2014, 10:26 PM
Doc Yota's Avatar
Default Coolant leak from under throttle body
Hello all. I have a d16z6 that has a coolant leak(drip) that seems to be coming from underneath my throttle body. I have no idea what it could be. Has anyone ever experienced this problem? If so, how do I repair it. It seems to be something simple.
Old 04-24-2014, 06:04 AM
Hysterically Calm
TomCat39's Avatar
Default Re: Coolant leak from under throttle body
D16Z6 should be the 92-95 series and so would have the Fast Idle Thermo Valve (FITV) which uses coolant temperature to operate and resides on the underside of the throttle body. Most likely candidate for coolant leak just under the throttle body.
Old 04-24-2014, 09:23 PM
Doc Yota's Avatar
Thanks a bunch. I will look again to confirm. Let me ask you this TomCat39, I think I have a hose missing from the diagram you provided. The illustration just above section 4&5 has a small nipple sticking out to the right of the O-rings just beyond the wax. Does a hose attach there? If so, my hose is missing.
99ctr
10-05-2005 12:23 PM
4DRmafia
09-03-2005 10:17 AM
mini-cRx
03-24-2004 09:18 AM
oOPreludeBoyOo
07-13-2003 02:56 AM
wanttorace
07-08-2003 08:28 PM
Quick Reply: Coolant leak from under throttle body
