Help with D16ZC SOHC Vtec swap
Old 05-04-2014, 05:40 PM
ukinayo_dc5's Avatar
Default Help with D16ZC SOHC Vtec swap
A couple months ago my motor blew (D16Y8 ) in my 2000 Honda civic EX,
about 2 weeks ago I purchased a used D16ZC Vtec from Hmotorsonline. The sales associate gave me some info before I installed the motor in and told me to swap a few parts and here is a list what I've swapped and installed;
-Y8 Crank pulley and Crank sensor
-Y8 Intake Manifold since the IACV was positioned differently and the connectors were different
-Y8Throttle body with sensors
-Y8 Fuel injectors
-Y8 distributor, cap and rotor
Also installed new;
-Water pump and thermostat
-Spark plugs and wires
-Y8 Timing belt
Please let me know if im missing anything else that I would need to swap over.
Now, the issue
My idle would stay at a consistent 1700RPM Until I had some throttle, the Idle then drops to 1K then jumps up and down to about 2k. I have checked the IACV and even swapped with a buddy of mine and the problem still continues. But I did notice that once I spray the intake manifold flange(where the manifold bolts to head)with carb cleaner the engine starts to bog and die out..it seems as if there is a leak or the gasket isn't helping it seal correctly. I did however buy a new Y8 intake manifold gasket from Honda but it didn't help, would I need the ZC intake manifold gasket for it to seal correctly?
Here is a quick video
Any help or advice would be greatly appreciated
Srt.ej1
08-28-2016 11:44 AM
uindaway
13
11-01-2012 01:05 PM
RiTtEk401
10-23-2011 06:12 PM
boostedion
18
04-12-2011 05:16 PM
max23
10-18-2005 06:14 AM
Quick Reply: Help with D16ZC SOHC Vtec swap
