1995 del Sol Si Cruise Control Issue
Hey everyone:
I'm about to take this car on a 1,400 mile road trip. I've done a major tune-up to the car, new valve cover gasket, fuel filter, air filter, new spark plugs and wires, and new tires. I now need to fix the cruise control.
I have power going to the main switch (green light comes on for the button), but when I hit set or resume on the steering wheel controls, nothing happens.
My mechanic checked all the connections and fuses, no issues. Any thoughts?
Thanks in advance,
Scott
Thanks in advance,
Scott
Oh look, I can change this
Re: 1995 del Sol Si Cruise Control Issue
Also, use the service manual to troubleshoot your cruise control system. It is very good at narrowing down the problem. The 92-95 Civic manual will have the same basic components as the del Sol so you can use that one in a pinch.
Cool Cool Island Breezes. BOY-EE
Your clutch pedal height may be out of adjustment. Or your brake lights are always on due to a bad switch/incorrect height adjustment.
Or your horn/brake light fuse is blown.
Horn works, just the cruise doesn't work. It's an automatic, but I'll check the brake pedal as well. I'll definitely double-check the fuses. Which fuses would be affected?
Thanks in advance,
Scott
Thanks in advance,
Scott
xboxhaxorz
08-04-2017 04:21 AM
delsolguy32
06-06-2011 09:03 PM
mac_24_seven
08-31-2009 09:15 AM
