97 ex slightly overheating
1997 civic ex coupe 210,000 miles
little unknown history just purchased few days ago
owner had put new dizzy cap and rotor button on it because of occasional stutter
the car will run slightly higher than normal temperature and sometimes spike to about 3/4 way to the H the come back down to normal. never runs half way like every other civic Ive had
no check engine light
I put a new oem thermostat in and made no difference
checked coolant and its full
did a compression test thinking head gasket may be blown
cyl#1 150 cyl#2 155 cyl#3 150 cyl 4 couldnt get the darn plug out it was super hard and didnt wanna strip anything.
Ive noticed NO power loss except a very seldom once in a while stutter or miss
just drove it 5-10 miles and it stayed around here
it will gradually rise above what the pic shows and then drop back down
it will usually stay a little bit lower than that but def above the middle where its supposed to be
there is no smoke at all except a very little black puff under 100% acceleration from a stop
so could the water pump be acting crazy?
is there a way to test it?
whats my next step here
Re: 97 ex slightly overheating
I haven't done any of that yet except for the thermostat if you think a water pump and tensioner would help I'm going to do it and a timing belt
Steve at Heart
Before throwing parts at it make sure the fan functions and the fan switch is still operating. I would also pressure test the system to see if your losing any coolant. It is possible that the headgasket is slightly leaking.
Gabe_Ng
08-15-2012 06:29 AM
GoLowDrew
15
05-08-2006 04:24 PM
