92 Honda civic taillights/corners not working
Hey HT I have my 92 eg Honda civic and I noticed when I tried to take my for a drive at night that my cluster, climate control, taillights, and corners where not working. I have blinkers, brake lights, headlights and hazards. I Checked I Believe Its Fuse 19 The Fuse Was Good But Replaced It With A Known Good One And Nothing. Has anyone seen this please advise
Re: 92 Honda civic taillights/corners not working
For the cluster and climate lights one common part is the dimmer control on the left of the steering wheel. That control unit connects to quite a few lights in the cabin.
Also check fuse 40. I believe it's an under the hood fuse. It is prior to your dimmer and the multi light control switch on the steering column.
If neither of those are fruitful for you then I would suspect shorted wiring or bad grounds.
There isn't a common denominator for all of the lights you are having issues with.
There is also some grounds that could be affecting your lights. G201, G401, G301, and the tail lights section for the hatchback it's looks like G553 and G771.
When you say the corner lights I'm assuming the parking lights (same as blinkers but dimmer)?
Thank you for your response I will check the fuses and grounds you have listed, the problem I was having was that they are not all on the same circuit as you mentioned. And as for my corner lights yes I meant my parking lights do not come on the only lights that I have come on when my multi function is switched over are headlights. BOO switch is working and re verse lights are working as well as turn signals I will let you know the results when I check everything here in about an hour
Nural
10-25-2006 08:00 AM
Mike36
02-26-2003 08:14 AM
