d15z3 MA9 civic 5 wire o2 sensor wiring help
Cheers everybody!
Theres an o2 sensor signal alternator or something in my motor bay.
My cel is on because of the primary o2 sensor so i would like to eleminate that useless little thing. If i cut the wires where i put the red circles and reattach them again without the gadget, it shall work fine, right?
Also, is there a special way to reattach them or i can do it simply by use some terminal blocks?
Thank you guys!
Thank you guys!
Re: d15z3 MA9 civic 5 wire o2 sensor wiring help
Anyone?
I know that this is pretty straightfoward to most of you guys but i am really just got into this car stuff and dont want to spend about 300$ for a new oem 5 wire o2 if the current one is working perfectly without that signal alternator thing.
So please help me guys can i just cut that ˇ°#&˘! out?
Thanks!
Thanks!
That thing is modifies the output voltage of the primary o2 sensor to bring richer mixture to the engine.
The code is P0132 witch is stands for o2 sensor high voltage reads.
Thats what i was able to find out, and why i hope that if i remove the modifier than everything will be ok
Ok, i have rechecked the code myself and it is code 48 . So its heated o2 sensor. Dont trust anybody else, its not even OBD II....
So, someone confirm me please, can i cut that stuff out?
JoshJosephKeith
05-04-2009 04:38 PM
slwazgsr
10-17-2002 06:53 PM
