Rebuild. Engine squeal?? Help
Old 04-22-2014, 08:28 AM
Jorgeb94's Avatar
Icon2 Rebuild. Engine squeal?? Help
Got done with d16z6 vitara rebuild.and a belt squeal comes from the engine once it's a operating temp. It goes away as I acceperate but returns at idle. Used gates racing timing kit comes with timing belt and water pump I installed them but used old tent ironed which was fine. I've eliminated both belts alternator and ps but the sound does get more faint with them off. It sounds like a belt squeal. A buddy of mine says he hears it coming from the trans. I've never heard of that sound from the trans but maybe someone on here knows? I really need to solve this to get my car running.
Here's a YouTube video of what it sounds like
Old 04-22-2014, 09:12 AM
Jorgeb94's Avatar
Default Re: Rebuild. Engine squeal?? Help
Bump for some help please.
Old 04-22-2014, 11:43 AM
crazyhouse2011's Avatar
Sounds like a pulley, not a belt. As to which one, I couldn't tell you, but did you replace the tensioner pulley for the t belt?
Old 04-22-2014, 02:57 PM
Jorgeb94's Avatar
Nah I didn't. But a buddy of mine keeps saying it sounds like it's coming from the trans. Is this a possible noise from a trans?
Old 04-22-2014, 03:00 PM
I never narc'd on nobody!
NotARaCist's Avatar
That's bearing squeal. Inspect your axles - are the CV boots damaged? Did you eliminate the accessory belts by removing them, or by replacing them?
Old 04-22-2014, 03:20 PM
Jorgeb94's Avatar
By removing them. Axles are fine they're new too since I was putting in the rebuilt engine I got quite a bit of stuff new. Radiator and fan and hoses. Where else from the trans could it be from?
Old 04-22-2014, 03:38 PM
JoeBlue's Avatar
Honestly sounds like metal on metal scraping. It has to be a bearing or a cam cap.
Old 04-22-2014, 03:42 PM
Jorgeb94's Avatar
Cam cap? What would make that squeal? Also what bearings should I check? It seems to loud to be the tensioner but any ideas?
Old 04-22-2014, 04:11 PM
JoeBlue's Avatar
What exactly all did you replace when rebuilding this engine? Did you follow a particular guide or anything?
It's a rotating piece of metal doing what is called "chattering", as in it's only hitting the stationary piece in oscillation. That is what makes that sort of pulsing squealing sound. It will only hit at a certain RPM and only every so many revolutions.
From my experience it is caused by loose cam caps allowing the cams to flex. I don't know if it's the same on the Hondas as OHV Fords though, but that is what causes that sound in Mustangs.
Old 04-22-2014, 08:15 PM
Jorgeb94's Avatar
I replaced main bearings, rod bearings, rods w/ Scat H beam, vitara pistons, piston rings gaskets head, cam, oil pan and valve, Thermostat, head studs, crank shaft, torqued everything to arp and honda specs. All parts were honda. Except for oil pan and piston rings and bearings they are king and npr.
How would I fix the problem? Re torque the cam shaft gear?
Old 04-23-2014, 01:38 AM
NotARaCist's Avatar
Did you spec the journals for bearing sizes, or did you just slap standard bearings in there? Are you seriously running Vitaras on stock length rods?
Old 04-23-2014, 06:35 AM
Jorgeb94's Avatar
Measured everything could have sworn I said H beam.
Old 04-23-2014, 09:13 AM
Jorgeb94's Avatar
Reason my concern on trans is cause this is a used one I bought and just put it on. But I doubt trans make this sound. Any other ideas what it could be? How could I fix this?
Old 04-23-2014, 09:58 AM
Hysterically Calm
TomCat39's Avatar
By this, do you mean plastiguaged?
Did you at any point remove the rocker arms from the head? Or did you leave that untouched when you changed the head studs?
If it were tranny related (manual tranny) the sound should disappear when you put in the clutch and the tranny shafts stop spinning. The exception would be the pilot bearing, it spins as long as the engine is spinning.
Old 04-23-2014, 10:24 AM
Jorgeb94's Avatar
Yeah I did. I changed the lmas with some new one but retorqued. I does go away when I drive in gears but in neutral it makes the sound. It has a whole new clutch kit installed. And yeah I plastiguaged it like the Haynes manual states too.
Old 04-23-2014, 01:30 PM
NotARaCist's Avatar
You did say H beam. The rod style has absolutely nothing to do with the rod length, though. Vitara pistons on stock rods puts your compression stupidly low - have fun with shitty gas mileage, and absolutely, painfully **** power out of boost.
Old 04-23-2014, 02:52 PM
Jorgeb94's Avatar
No I had to knotch to block for those to fit. Anyways I need help with the problem so any ideas?
Old 04-23-2014, 03:29 PM
NotARaCist's Avatar
Did you spec ALL of your journals, or just one? Have you done your post-warm-up, 50, and 500 mile oil changes yet? What oil are you using? Was there any debris in any of those oil changes? When you plastigauged, what did you spec your bearings to?
Old 04-24-2014, 08:19 AM
Jorgeb94's Avatar
Spec all. Haven't ran it simply cause of this noise. Does it sound like a rod or main bearing?? If so I'll open up the oil pan and check it out.
Old 04-24-2014, 11:16 AM
NotARaCist's Avatar
If you aren't going to answer all questions posed, you aren't going to get any real help.
Old 04-24-2014, 12:36 PM
averyvm's Avatar
Try using a screwdriver to help detect where the sound is coming from. To do this you put the handle part of the screwdriver up to you ear and then put the metal part on different parts of the engine. This is like a boot-leg stethascope.
Old 04-24-2014, 02:10 PM
Jorgeb94's Avatar
My buddy did that with the auto stethoscope that's why he think it's the diff inside the trans. It was measured to stock spect I forget the number like 45mm or so with 75 bearings I think I'll have to check my notebook. But that's what friend told me it's the trans anyone had an experience like this with the trans?
Old 04-28-2014, 07:28 PM
Jorgeb94's Avatar
I figured out it's coming from the clutch or trams related it's not the engine. I sawped out the trams and it makes it but a lot more faint now. And it gets louder as I press the clutch in. Any ideas on what it could be. The whole clutch was already replaced.
mikey88
04-19-2017 10:57 AM
JusAccord
03-30-2012 06:24 AM
ramonjones16
12-07-2009 06:35 PM
Farkis
04-28-2005 02:58 PM
green98civic
01-04-2004 11:16 AM
Quick Reply: Rebuild. Engine squeal?? Help
