nut on inside of subframe broke off
Old 04-22-2014, 08:18 AM
PrettyMuchBoned's Avatar
Default nut on inside of subframe broke off
5th gen
What would you do? The nut on the inside (inaccessible) for the control arm broke off. I was considering replacing the subframe or cutting it so I may weld a new nut for the bolt. But I dunno if that's a good idea.
should be able to get subframe for 40-75$
Old 04-22-2014, 09:13 AM
Default Re: nut on inside of subframe broke off
Someone explained me how to do it and I'd rather spend the 50$ on a new one lol
Old 04-22-2014, 09:36 AM
TOP91's Avatar
Are you talking about for the bracket?
Old 04-22-2014, 11:31 AM
I'm talking about for the control arm where it bolts to the subframe, opposite side of the control arm from spindle.
Old 04-22-2014, 07:26 PM
75$ ain't bad for a good rear engine mount, fatter sway bar, and a new subframe with less rust
is there a way to fix this subframe tho? I'd like to have a spare
Old 04-22-2014, 07:33 PM
90crxdriver's Avatar
One of them broke loose on my sub frame. I drilled a hole under where the bolt should be and opened it up enough to get a wrench in to hold the nut and tightened the bolt as tight as I could then welded the nut back to the sub frame as much as I could. Then tightened the bolt some more. After that I welded in a filler piece and painted the exposed metal and welds.
myownreality
02-09-2013 10:43 PM
LutherX
08-21-2011 07:59 AM
allums34
04-13-2011 09:55 AM
vteck1ck
14
11-14-2008 08:55 PM
eg6civic1538
03-20-2008 04:45 PM
Quick Reply: nut on inside of subframe broke off
