fan is not working
fan is not working
So i just replace my radiator fan and fuse<(junkyard).starts up fine but when i sit in traffic it throws #6 code and it start to over heat?So now is it my ECT sensor or my fan assemble? d15 non-vtec advise is need!
brandon
brandon
HRD PKR
Re: fan is not working (94c1v1cex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">replace the ECT and if that doesn't work try getting a new fan and not an junkyard one.</TD></TR></TABLE>
the junkyard van is prob fine, if the engine coolant temp sensor isnt working it does not know when to kick the fan on cause it dont know the engine temp.. so get yourself a NEW coolant temp sensor.
Re: fan is not working (B16B_coupe)
Nobody mentioned water flow issues or thermostat problems, are you sure you have good flow. Does your car not have a fan switch seperate from the ECT.
xpdude
11-05-2009 05:39 PM
Rayz_Si
13
02-27-2008 08:29 PM
hardboiled egz
11
06-17-2003 10:08 PM
