Quick Help! Engine Harness I.D. (EK Civic)
Here is my problem. I have a 97 Civic EX with a OBD2a ECU. Im positive. Im running a D16y8 motor. I gave my friend my harness, b/c i thought about doing a swap but ended up getting a new d16y8 block to replace mine. Anyway, I got a new harness and it suppose to be a OBD2a from a 97 civic, but i beg the differ. can someone tell me what the heck is missing from this harness. The alternator plug was cut off and I sodered another one one b/c the wires were still on the harness. I thought there was a missing ECU plug and I think it is an OBD2b harness that i have. Someone let me know please! thanks. Only the blue plug went into the 3rd slot also know as "C" and the green plug went in; the one mounted on the side of the ECU. The remaining plug, the gray one, did no fit anywhere, plus, I would be missing Plug "D" the small one for the back of the ECU.
Here is the harness I was sent:
And Here is a pic of the female plugs on my ECU, if you need.
http://technet.ff-squad.com/wiring.obd2a.htm
Modified by 1wiperDude at 11:02 AM 11/17/2007
Re: (EjSex)
wow you should send it to rywire and have then work out your problem for you they do alterations to stock harnesses and stuff like that so gto rywire.com call them and talk to a guy named peter he is really helpful!
Re: (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">you got one fucked up harness... ill compare it to my obd2a one when i get home and let you know dude</TD></TR></TABLE>
thanks man! Love ur car BTW ... fookin clean!
Re: (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">prob not! he is missing his 3rd ecu plug</TD></TR></TABLE>
yeah i figured that... and the "A" slot on the ECU is likt injectors... ect.. ect... so its all important. And I dont have one that fits in there.... all and all either i send it to Rywire to get it re-wired... or find a new one...
HRD PKR
Re: (Sloshy)
yeah, its not a ex harness.. i thought thats what you was asking! lol.. it is a si one tho. but you can get a obd2b to obd2 a jumper or obd1 what ever ecu u using
if i remember correctly my Si harness only had two plugs and a green one just like yours so mostly like it
is an si harness, check the injector plugs and vtec plugs, in obd2b non si harness the dizzy plug should be smaller plug, the SI harness has the big plug like all the integras and civic
Re: (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">its a si harness man, your correct</TD></TR></TABLE>
Thanks everyone for the input ! I was going nuts trying to figure out if i just needed a jumper harness or if i was completely missing a whole plug. Lol. Thanks again for all the input guys !!
HRD PKR
Re: (Sloshy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sloshy »</TD></TR><TR><TD CLASS="quote">if your gonna use it on a 97 it wont work btw</TD></TR></TABLE>
if he gets a jumper it will
HRD PKR
Re: (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">yeah, its not a ex harness.. i thought thats what you was asking! lol.. it is a si one tho. but you can get a obd2b to obd2 a jumper or obd1 what ever ecu u using</TD></TR></TABLE>
nello a.
12-24-2008 12:20 AM
