Check engine light on when i change the transmission...
Does anyone know how to turn the check engine light off when you change the automatic transmission to manual???
Re: (Bazza)
it has to do with the ecu.that is why you are running a cel. i would eathier get a maual ecu or open the ecu and i heard that if you just move a pin in there one spot over then it should be good
Re: (mini-meEj1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-meEj1 »</TD></TR><TR><TD CLASS="quote">it has to do with the ecu.that is why you are running a cel. i would eathier get a maual ecu or open the ecu and i heard that if you just move a pin in there one spot over then it should be good</TD></TR></TABLE>
search it on here if you cant find it here google deff has a link for you....
or you can always pull the bulb jk dont be half ***
hondaeg95
23
01-20-2004 04:51 PM
