Issues after a swap (B18B1 into 93 civic si hatch)
Ok...the motor is in and runs. Sorta. The tach is not steady, it jumps. The engine is choppy at anything below 2000 rpm, and idle is very rough. The speedometer doesn't work at all, neither does the odometer. The tranny is out of a GSR teg, and I have no reverse. I can get the shifter into the spot that should be reverse, all the way to the right and down, directly below 5th, but the car moves forward not back.
I know with the speedo it could be a bad vss, but I don't now how I would go about checking that without buying a new one, and I'd prefer not to if the one I have already is good.
I have adjusted the throttle cable as well as the timing as well as I can and there is next to no difference in the idle and general overall choppiness.
Any kind of input on any of these problems will be greatly appreciated.
HRD PKR
Re: Issues after a swap (Banjo the Ninja)
check engine light?
to check your vss for most common problem. remove the plug and look down on the connectors to see if there is corrosion built up on them, and make sure the pin's are tight and not loose..
did you install the reverse switch?
you might have a intake leak or a vacum problem also.. check over the intake mani..
What ecu and what dizzy are you running?? If you made a conversion harness for the dizzy, the directions on the internet are usually wrong and 2 wires need to be switched. Check to make sure all sensors are hooked up and that they are hooked up properly. Use a manual and look at what color wires go to which sensors cuz some of the plugs are interchangeable. Hope this helps.
Yes, cel is on, but haven't had a chance to run the codes yet, it's down at the shop getting the alignment checked right now.
Reverse switch? Lol I feel like a retard. Can you give me some info on where it would be so I can check? A friend of mine did most of the work on the bottom end because he's a lot scrawnier than me.
I will post some pics of the intake and such, I've got everything I could see plugged in, except the line coming from vacuum that I was told just runs to a charcoal box and won't hurt anything if left open.
The ECU is stock LS, as is the distributor. The ECU came from same car as the motor, the dizzy came from canada by way of ebay, but seems to be functioning properly
I didn't make a conversion harness because I got the engine side harness with the motor when I picked it up.
HRD PKR
Re: (Banjo the Ninja)
the reverse switch is on the bottom front side of the trans
check the engine light and let us know the code. that will tell you your problem.
I will be sure to once I get a chance, but for now the problems aren't enough for me to hold off my trip to colorado. I will post information as it's available.
Make sure you don't have vacuum leaks, plug all the lines that aren't hooked up. And make sure the plugs go to the right sensors, im guessing those 2 things will take care of at least part of your problem.
Re: (inspector01)
Ok, yea the distributor was loose and that was the problem with the tach, as well as most of the issues with how it ran. The idle is still funny, I'm going to plug the one vacuum line that isn't plugged in to anything then run it down to advanced auto parts to get the codes read and I will post more later tonight or tomorrow.
why are you going to autozone to get the codes read?
you have to be able to manage putting a paper clip on the port to pull the codes yourself, the directions are in the faq.
Re: (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">the reverse switch is on the bottom front side of the trans
check the engine light and let us know the code. that will tell you your problem.</TD></TR></TABLE>
Other then turning on the backup lights,im just curious what the reverse switch has to do with this guys issues. Its a five speed not an automatic.
As far as the idle and CEL,just double check your vacuum routing and make sure you have the proper vacuum to the map sensor.
Now for the shifting,did you use the spring pin on the linkage? If you used a 12mm bolt like alot of noobs you'll have lots of slop and possibly not be able to get it in reverse. Let us know.
Yea, I'm not sure about the spring pin. I'm going to assume it's a 12mm bolt, but I am not the one who hooked up the linkage since the car is so low to the ground even on jack stands, but the shifter is extremely sloppy. However, I have been able to get it into the gear where reverse should be, directly below 5th, but the car moves forwards not back.
Regarding getting the codes checked, I'll go do that now with a wire, I wasn't aware of how easy it was and in the mean time I had to replace my wheel bearings, lower control arms and outer tie rod end on the right side.
Ok just went to check the codes...and nothing. started the car back up and the cel is off, I'll wait for it to come back on, it sometimes goes off and comes back on fifteen or twenty minutes of driving.
Also, I checked out under the hood.
Not sure where this line leads to or what it's for...
These pics show the only vacuum line I have that's not plugged in.
[QUOTE=Banjo the Ninja]but the shifter is extremely sloppy. However, I have been able to get it into the gear where reverse should be, directly below 5th, but the car moves forwards not back.
[QUOTE]
If the correct pin wasnt used then yeah ur shifter will feel really sloppy... SO sloppy that u may think ur in the right spot for reverse but ur really in 4th still. Are u pulling the shifter ALL the way to the right then down? I know before honda shipped my shift linkage pin in i was using a bolt and i had the same problem except i was trying to shift 4-5 and instead i would always be going 4-3. Good luck with that though
[QUOTE]
Yea, I have that problem unless I go waaay to the right I'll hit 3 instead of 5, but after a couple hours on the highway to colorado I got that figured out, so I'm pretty sure its hitting revers, but can't really swear on it.
Re: (HiyahBeech!)
That vacuum line goes to your purge control solenoid. It was on the back right of your single cam intake. Black solenoid with a little cap like thing on it.
Re: (IMALLSLO)
B18B1 is dual cam, does it go to the same place? I have a line running from the intake manifold to that solenoid right now, I will take a picture and post in a minute.
Is this what that hose is supposed to plug in to? It looks like there should be a little nub for the hose to plug on that got broken off, I will run out to the junk yard tomorrow and see if I can grab one.
Modified by Banjo the Ninja at 7:41 PM 12/1/2007
Re: (IMALLSLO)
Fantastic, thanks a ton, I'll let you guys know how it goes. Even with all my stereo equipment in the car it's still pretty ballsy considering it's running like ****, can't wait to get it running right.
Hope someone knows the answer here, is this solenoid the same as the one on a B16? I don't want to drive an hour to an acura dealership to get something I can get at the honda dealership 5 minutes from where I live.
It's the evap purge solenoid? Or the fuel mixture solenoid?
Re: (IMALLSLO)
I can't, the nipple for the hose to plug on is broken off of the one that's on there. Honda can't order the one off of the b series si's for some gay reason, but I found one at the junk yard on a core return, not quite the same but close enough I hope, I'm gonna put it on tonight or tomorrow.
nkcalvert09
04-25-2011 06:48 PM
