crashed!
crashed!
A couple of days ago i got into a minor accident with a wall i hopped the curb (pretty hard)and sild against a wall.the damage isnt too bad i just need a passenger side fender and corner light...well anyways my problem now is that my sterring wheel is turned 1/4 to the right and the wheels are straight, if i try to straighten out the wheel while im driving the car goes to the left.Also when im driving the car tends to pull to the right. i jacked the car up and everything under the front end looks ok...but the car just does not feel right.The wheel wobbles when im driving too.if anyone could help or just give me and info. of what can be wrong i really appreciate your time thank you soo much.
* B A N N E D *
Re: crashed! (EgK2o09)
check out your outer tie rods and wheel bearings.. Basically all you do is jack the car up in the air and wobble your front tires right to left to see if there is any play for your tie rods.. and to check if you have a bad wheel bearing wobble your tire up and down, you just got to check for play... But anyways like 95ProjectEJ1 said.... check those also.. Good luck bud
Re: crashed! (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">Hoping a curb in a car isn't always a minor accident. A few things should be looked at
Alignment
Axels
Control Arms (bent)
Rims (bent)
I would take your car in to a shop and have it inspected. </TD></TR></TABLE>
he is right..and your radiator support might have bent too
Alignment
Axels
Control Arms (bent)
Rims (bent)
Re: crashed!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgK2o09 »</TD></TR><TR><TD CLASS="quote">95projectej1 are the front lower control arms a dealer item or can i go pick them up at a local parts store?</TD></TR></TABLE>
You can call Autozone, Kragen, Checkers etc and check... but I would most likely check the marketplace and find a good used one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgK2o09 »</TD></TR><TR><TD CLASS="quote">thanks everyone for your time and replys </TD></TR></TABLE>
Yeah, have it checked. I hit a pothole at like 15 mph and broke an axle.
r3000
12-20-2004 09:29 AM
