THe most important THIng??
Im thinkin about boosting my D16Y8 and i was wondering what are some really important things to change or re-do or get stronger of if i plan on boosting ??? appreciate the tips!!
HRD PKR
Re: THe most important THIng?? (VTECboy97)
if your looking to make like a high hp y8, i would rebuild the motor sleeved, etc
daily you can piece together a good kit for fairly cheap, and spend some good money on tunning and you will be set...
dseries.org has some good info iam sure... check it out
Former Moderator
Try the boost forum - this might turn into a "Don't boost it!" vs. "Boost it!" topic since it's in the Civic forum, not the boost forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECboy97 »</TD></TR><TR><TD CLASS="quote">Another quick questions. How much is a average for spending on a turbo set up ??????? </TD></TR></TABLE>
All depends on what your intentions are. You can piece a crappy one together for 1500+, get a full kit for 3k+, or a custom turbo setup for over 4k. Going turbo is not cheap what so ever if you want it done properly.
I have seen turbo's go for 700+ and the manifold/DT/DP go for 1k+ easy. Dont forget you still need the IC, WG, BOX, Oil/Vac lines etc etc.
Re: THe most important THIng?? (95ProjectEJ1)
i KNow they are not cheap at all but i think i will have about 3500 to 4500k maybe even a little more, and idk where really to start getting parts or what i should start doing to get the motor turbo ready and i was looking at an ebay turbo get but its one of the little more expensive ones kinda and idk i just need a little guidence??
osbunjosh
14
11-11-2011 02:51 PM
