cel 41 question
cel 41 question
I have a gsr swapped civic with a p28 ecu. I recently put a new chip in with the stock gsr map. Once I did this I immidiatly got a code 41. Now my gas mielage went to crap and I looked at the o2 sensor and its a 3 wire with a wire nut in between connector and o2 sensor and the wire is white. my question is why would this come up now with a different chip? is it the wrong 02 or bad? and did my old chip had it disabled? but wouldnt that of meant my gas mielage would of still been as bad as it is now?
Re: cel 41 question (Z you later)
u mean u got a chipped p28 ecu,right? and if it is throwing code 41 that means your o2 sensor is bad.that happened to me once before and simply replace it with a new one and code will go away..but your o2 sensor is only 3 wires? normally it is 4 wires or 5..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Z you later »</TD></TR><TR><TD CLASS="quote">yes chipped p28, yea its a 3 wire which is why im confused since I thought it was 4 wire also.</TD></TR></TABLE>
m... u can try to get a newer o2 sensor with 4 wires...i got a used one from junk yard and it is still working fine..
Re: cel 41 question (crazyguy)
i had something similar happen to me i changed back to old chip and problem was solved. i later got new chip that had the right maping and it works great now!
Re: cel 41 question (BUDtoker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUDtoker »</TD></TR><TR><TD CLASS="quote">i had something similar happen to me i changed back to old chip and problem was solved. i later got new chip that had the right maping and it works great now!</TD></TR></TABLE>
i put my foot in my mouth my cel codes are back o2 and ait showed up like magic 2 hours after i posted grrr oh well
