Help with Wiring. Gsr motor into an EG.
Just purchased an EG shell due to my DC gsr being in a wreck. Im going to swap my motor into the EG which has the engine harness. the last owner told me he was having problems with his vtec with the wiring harness. so i was wondering if i can just take my wires from my integra and just put it into my EG? whatever i need to buy to make this thing run please let me know. thanks a lot.
Re: Help with Wiring. Gsr motor into an EG. (xblitz22)
just run the engine harness from the dc into the eg and you will also need the axles, shiftlinkage,and the ecu from the gsr
Re: Help with Wiring. Gsr motor into an EG. (mini-meEj1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-meEj1 »</TD></TR><TR><TD CLASS="quote">just run the engine harness from the dc into the eg and you will also need the axles, shiftlinkage,and the ecu from the gsr </TD></TR></TABLE>
x2 mounts too
x2 mounts too
Re: Help with Wiring. Gsr motor into an EG. (94c1v1cex)
really thats all i need? whew i thought i was gonna have to start cutting wires up and connecting it to other things. thanks a lot!!!!!
Re: (xblitz22)
i believe you would have to do some fab. work to make it fit but if you don't feel like doin that just get a ex manual gauge cluster..(i am assuming you don't have a tach. or that you just want the interga cluster in there for ***** and giggles?)
Re: (mini-meEj1)
ohmm how about the harness behind the dash? my friend keeps telling me something about it. does it hook up with the engine harness or i dont have to worry about those wires?
Re: (xblitz22)
you shouldn't have to..you don't have to worry what runs in the car being that all the gauges and stuff in the cabin get there readings from the ecu.so in reality all you need is the engine harness and the ecu
Re: (mini-meEj1)
well unless your shell had a vtec engine before you need to add the wires for that and you will also have to wire up the knock sensor and the secondary butterflies to use the p72
Re: (USDMCIVICHATCH)
mini-meEj1 said i can just use my integra engine harness so thats what im gonan do. but thanks anyways.
Modified by xblitz22 at 12:59 PM 11/13/2007
Former Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH »</TD></TR><TR><TD CLASS="quote">well unless your shell had a vtec engine before you need to add the wires for that and you will also have to wire up the knock sensor and the secondary butterflies to use the p72</TD></TR></TABLE>
Yup.
Here's a few helpful items to locate proper pin location to add IAB (butterfly) and knock sensor wires:
And some detailed pin-outs in case you need them:
http://technet.ff-squad.com/wiring.obd1.htm
Yup.
