p07 ecu hurting me or not
vx hatchback
just insatlled a jdm d15b vtec motor from hmotorsonline.com
turned out the distributor was bad on the motor we got so we put in a z6 distributor.
the car isn't running right, feels like it has no power and just dies when you try to take off.
question:
seeing that its a jdm d15b motor with a z6 distributor, would using the VX ecu cause a problem and make the car run bad?
only cel its getting is for the o2 sensor. everything is hooke up right and the car is on timing.
question:
Re: p07 ecu hurting me or not (VRD^sam)
what conversion?
if your talking about the o2, no. i don't have an o2 sensor at all. there is one on there, but its a 4 wire and its not good.
you think not having that 5 wire o2 and still using the vx ecu is the problem?
Re: p07 ecu hurting me or not (boostedeghatch)
this should hellp...
http://hondaswap.com/swap-arti...3759/
get your hands on a p28, do the converison and you should be golden
spyderracing
18
10-13-2004 11:17 PM
spyderracing
11
10-05-2004 03:58 AM
